Alternator help on old chevy 350
Hello all, I have an old 3/4 ton chevy truck (1982) it came with a 6.2 deisel in it, and I put in a 383 that I made from a 4bolt main. I have always used the wiring that was in the truck when I got it, and that may be part of my problem. The batery died in it about two weeks ago, so I put in a new one, and no problems until today. After I was driving around for a while, I parked and when I tried to start it, it was very slow to turn over. Lucky for me my engine always starts on the first crank, otherwise I would have been stuck. I got home, and I pulled out the multimeter and I cheked to see what the battery was at....14.12 - 14.25, so I put on the heater and lights....still at 14.25....so I am thinking wth??? why did the truck seems to be near dead an hour ago? I watched the voltmeter in the truck drop when the lights when on, then go back up. So I start looking at the wiring to the alt and battery, terminals etc. All I could think off is that maybe I am using the wrong gauges of wire, or I have it hooked up wrong. I have had problems on and off with the battery and alternator since I put in the motor. The alt is only five months old, and the battery is about two weeks. The wiring to the battery from the alt is a 2gauge from a old car stereo, I am assuming after reading one of the articles in the knowledge base that this could be the problem, I would also like it if I could get a schematic, or a link to one, of how I should be wiring the charging system, and the gauge of wire I should be using. See I live in Vancouver BC, I bought the truck off a guy who was lived in surrey. If any of you have ever been to surrey, or seen the people that live in bridgeview, then you know what I am talking about. To make a long story short the previous owner was a crackhead, and I am still sadly enough using his wiring. I have changed everything else on the truck, but wiring problems in it are rampant.....many gremlins. When I first got the truck, I am not sure how it even started, as it had no negative lead attached?!? If someone could point me in the direction of a schematic with wire gauge I should be using...that would be sweet.
Thanks all Agent Spliff |
Doc here,
Sounds like you need some diodes in the alternator.. BECAUSE it is new does not mean it is any good! Do a draw test on the battery just sitting..it should be between .3 and .8 of am amp (depending on what memory type equipment you have running) be sure you other draws are off or defeated..Domes, hood, trunk glove lamps..or you will get a false reading. If it is above an amp, Totally disconnect the alternator, retest, If it falls back in spec, go get a kit or a new alternator..it's shot.. IF it does not, do a parasitic Draw test , (as above , meter configured for AMPS , highest scale, one probe on the cable the other on the battery) and remove ALL the fuses and relays..plug them back in one at a time until the reading shoots up..that is an offending branch circuit..disable or repair as needed, and continue on until all are back in place. YOUR GROUNDING MUST BE PERFECT ALSO!! It won't charge a capacity until it is..to do that: For your Ground Buss, Set it up as follows: BE sure First, You have A 4 gauge Cable (for stock battery location, OR , 0/0 or 0/1 Cable for a trunk location) from the battery, to any handy bolt at or NEAR the starter on the block . Using a short run to something like a seat belt bolt, or body bolt just adds resistance, the body is insulated..(has road paint and sits on rubber mounts) this , makes for a "Poor or no" Bonding situation..
To install a proper ground buss system, This MUST be done:
HOW TO MAKE WAY DURABLE CHEAP GROUND BRAID: --------------------------------------------------
This will be your braid cable, just Cut to smaller length's as needed, and tuck the cut ends into a crimp terminal and crimp the ends on.. IF you can Solder, Tin the ends before you tuck the ends of the cable into the terminals, then Tin the barrel of the terminals, then insert the cable and crimp.. Then heat the terminal and braid, feed some solder into the opposite end as the heat is being applied, let it melt and FLOW or WICK toward the heat..until the terminal barrel is filled and is smooth and shiny.. that is a good joint..gray and rough is a "Cold Joint" and you'll have to start over..
It sounds like a lot of work, but after you assemble all the parts, it's only a few hours to do..and you'll end up with a system that will work reliably for many years to come..and can eliminate that from your troubleshooting list. Remember: GROUND is the other Half of your 12 volt circuit AND is equally as important as having POWER to the device! Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Thank you so much
Doc you are nothing short of a god. Thank you, I am going to get right on it now until I run out of light, then finish in the morning. I will re-post with my findings and let you know how I made out.
Thanks again Agent Spliff |
alternator help
Or your starter to be failing. Didn't you say the problem was that it cranked over slow when hot? I think I'd do a voltage drop test on the starter ground and power circuits before I rewired my car. I've had the same symptom on a car with a dirty ground from the battery at the block. It's be a shame to do all the work you're talking about if it was only a matter of cleaning and tightening a bolt on the block.
Assuming the battery WAS NOT charged after being dead, on a Home Charger for 12 hours at 10 amps..Alternators will not..nor were they intended to Recharge a Zero to hero dead battery.. Their Function is to replace a high current "surface charge" lost during startup and support the electrical system ONLY while doing that..It will not replace a deep cycle charge lost unless your going on a cross country road trip with no system draws.. Quote:
YES , in fact you would see 14.4 volts at the battery..PURE output from the alternator..NOT the battery charge state..the battery may be FLAT dead..(or close to it..) and show 14.4 at the terminals on a running/Charging alternator..and YES, the draws would not effect the reading because the regulator is holding them high, (not cycling) due to the low battery. By virtue of the fact the terminals show a 14.4 running , it sorta precludes a mis~Wire..it IS charging..and the regulator PROBABLY is working.. Quote:
![]() SIMPLE as pie.. The "RED THERMAL" wire is a FUSE LINK or MAXI FUSE, about 70 amps worth..BE SURE you add one or the other to prevent future Fire.. ![]() That goes to the #1 Terminal...either will look like this and install on the solenoid side of a 10 GAUGE RED wire..to the alternator. The #2 and #3 Wires May be 14 Gauge RED , and BROWN wires..to The Alternator output (RED) and Charge lamp (BROWN). The #4 Terminal is a 10 Gauge BLACK that runs to your ground buss system..Don't forget this wire..It is as important as the #10 RED output wire!! Half of a 14 volt circuit won't charge a Battery, much less even light a small indicator lamp..a Circuit is JUST that ... TWO sides , POWER and GROUND to function..remove either side..you have nothing. (Single Fuse link) ![]() (Fuse Link Binding post and main buss power on a well designed home system ) ![]() (MAXI FUSE and holder) ![]() (Burned out Fuse Link) ![]() Choose any one of the link systems and properly install them for fire protection..This is what may happen when you get tired of replacing them because the "High Power Audio Amp" keeps blowing them out..and you stick in a piece od 0/0 wire instead.. ![]() The Fire Department , Traditionally lets these BURN until the battery EXPLODES, OR the cables BURN all the way through, and just control the fire..BECAUSE no matter how much water you throw at it..It won't go out until you remove Fuel, Ignition and Air..an Electrical fire will flare right back up when you move the water away because it has constant ignition (Battery Power shorted to ground) until it dies or is disconnected..unlike a carb fire.. Quote:
In addition to that you need to set up a ground buss system..which no kit provides..simple, few parts are needed, and take you about 1/2 a day.. For your Ground Buss, Set it up as follows: BE sure First, You have A 4 gauge Cable (for stock battery location, OR , 0/0 or 0/1 Cable for a trunk location) from the battery, to any handy bolt at or NEAR the starter on the block . Using a short run to something like a seat belt bolt, or body bolt just adds resistance, the body is insulated..(has road paint and sits on rubber mounts) this , makes for a "Poor or no" Bonding situation..
Got er done. It was sorta time consuming but time well spent thanks for your help guys 8)
It is much appreciated |
| finally finished chevy 350 build | redneckrodder | Engine | 7 | 05-30-2011 06:03 PM |
| El Camino Engine - 350 Chevy or 455 Pontiac | bjam2 | Engine | 16 | 08-07-2007 03:45 PM |
| 96 chevy 305 vortec heads on 350 block | badriand | Engine | 6 | 02-20-2006 07:45 AM |
| engine cooling specs for 350 4 bolt chevy | downunder | Introduce Yourself | 2 | 10-02-2004 10:41 PM |
| 85 chevy 305 heads on an 89 TBI chevy 350? | jazzguitar | Engine | 4 | 11-03-2002 04:11 AM |
