Alternator help, prob. diagnosis - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2005, 07:54 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
I think my alternator is dying due to being ran with a corroded and loose, positive batt wire connection for a couple days.
Here's the problem:
The volt meter drops to about 10.5 - 11 V right after I start the truck. After a couple minutes it will slowly go up to about 13.5 V (I think this is due to the electric choke shutting off on the Holley). During the day my volt meter stays at about 13.5 V, at idle or while driving. When I turn on my headlights, the volt meter drops to about 10.5 and if I keep driving with the lights on it will keep dropping to about 10 V.
Any idea's:
Diode's?
Brushes?
Regulator?
I guess I should tell you this is in my 76 K5 Blazer. The alternator has a flat plastic fan instead of the metal fan. I think it may be a late 80's Chevy truck alternator, possibly a 94 amp.
Old 12-03-2005, 01:55 AM
70bird's Avatar
Never mind.
Well, I went to autozone and bought a new alternator and a rebuild kit and was going to take back the one I didn't use. I have a buddy that works there and he said he'd take the old alternator as a core even if it was in pieces.
So I got home tonight at 10 PM and went to pull the alternator (I figured it to be about a 1.5 - 2 hour job, tops). I put my hand on the pulley and thought about belt tension. I tryed to turn the pulley by hand and guess what, it turned quite easily.
So, to sum it up, I tightened the belt, started the truck and let it run in the drive-way for about 5 minutes with the air and headlights on high and it stayed above 13 V the whole time.
I hate forgetting to check the simple things first.
Old 12-03-2005, 05:30 AM
aka Duke of URL
But at least you did and it saved you money to be spent elsewheres on it...
Old 12-03-2005, 09:23 AM
73oldsman's Avatar
...and I bet that you'll never forget to check for a loose belt in the future. Congrats on you discovery and return of funds!
Old 12-03-2005, 01:51 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Easy is always cheap!
Now invest a little of what was saved in a new belt and you'll be gold!
Thanks for the reply!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 12-03-2005, 08:20 PM
70bird's Avatar
I put new belts on in august but I never rechecked the tension after I drove it a couple hundred miles.
I heard once that you should recheck belt tension on V-belts because they stretch a little bit after the initial install.
Old 12-04-2005, 08:07 PM
73oldsman's Avatar
Never hurts to press on them occasionally to see if they've loosened up on you, while the engine is not running, of course!!! LOL!
need a lil help on a huge rust prob. 1st timer Body - Exterior 4 10-13-2005 10:11 AM
wire short or pump short prob wingedwolf Electrical 2 10-02-2003 08:17 PM
camaro air intake prob chevcamz28newbie Engine 3 07-15-2003 01:30 PM
Please Help with Exhust Prob RatFink9293 Engine 1 06-12-2003 10:56 PM
69' Boss 302 suspension/steering prob. 69boss Suspension - Brakes - Steering 2 07-30-2001 07:34 AM
