Alternator help on a sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2007, 09:40 PM
Hello all, and thanks for taking the time to try to help me. I have a 350 in a 82 3/4 ton truck. I am not sure if I hooked up the aletnator right, when I wiried it. Well actualy, since it is not charging the battery at all, I know I didn't hook it up right. Can anyone give me a schematic on what the wiring for the alternator should be? That would be great thanks
Old 04-01-2007, 05:37 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Depends on which type you have.
See attachments showing the common GM types.
vicrod
Old 04-01-2007, 06:58 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Traditionally, GM uses the 3 wire alternator. It is wired normally, Big red 10 gauge wire to the fuse link, then to the starter solenoid battery bolt.
The second red wire to either a horn relay power wire, or may just be jumped to the big red wire..both are fine, the relay is better for remote sensing.
The brown wire goes to the "charge lamp" .
A 10 gauge ground from the ground lug or mount bolt is needed for proper bonding, It will ground at or near the starter on the block, clean, burnish the area, and use star and lock washers.
  • 1) 10 ga output
  • 2) Brown "Idiot lite
  • 3) Red 12 volts horn or output wire.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-01-2007, 07:42 PM
Thanks
Once again you have saved my bacon. Thanks Doc, much appreciated. My truck is now charging properly, thanks.
Old 04-01-2007, 07:50 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Glad to hear it is fixed!
Doc
Innovations
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 11:46 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 10:43 AM
eaton m112 blower sbc manifold? oklowride Engine 3 12-25-2006 02:21 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 11:12 PM
