I agree. It looks like a DN alternator that needs an external regulator so without it your output will be based on rpm and will always be too high (unregulated).
Delco DN Alternator (google that) |
Looks like a fire waiting to happen
By the way I like the ICON under your name . That is a cool sign. I have one too.
Thanks so much for the replies. I looked back at the one I pulled off. It is a different alternator. Should i just take the old one in to auto zone or Advance and have them find one like it?
I'm trying to learn this stuff as I go. Thanks again. |
I went ahead and got a remanufactured alternator, that should be the same as the original.
Just to err on the side of caution, should I wire it like this? http://www.hotrodders.com/forum/atta...chmentid=23902 as that seems to be how the old one was likely hooked up. |
The number 2 wire well work were it is but should go to horn relay or fuse box + . That is the wire that tells it to put out more or less amps . Yes number 1 to hot with key on .My two cents
alt.
I would get the plug or two wire connector from a Gm parts dept. Wire number one terminal to the Acc. of your ING. switch and Number two wire down to the stud on the ALT. marked battery. both these wires should be #14 wire. Then I would run a #10 wire, If it is an older build does it have a ammeter or volt meter. If it has a ammeter run that #10 wire to the back side of the gauge to the + terminal, Then from the - terminal run the #10 wire to the Batt. terminal of the solenoid on the starter. I would run new wires Just because the others could be cracked and old, and I would add the flat connector because it would clean it up a lot. also when I do a car I use lots of wire ties and but it down by the intake bolts, you can also use wire looms.
Later 35terraplane |
Bubbahotep- I think its a regular 3 wire, like the original. Like i said the one in the picture i found in my garage, because the original was shot.
It has a voltmeter. Gonna try to set it up now. |
alt.
Then wire the #10 wire to the alt. Batt. stud, and the other end to the Batt. terminal of the solenoid on the starter, if it looks like the one you posted.
Later 35terraplane I missed where you said it was a three wire delete this Last edited by 35terraplane; 10-07-2010 at 01:50 PM. |
I think its good now. Running just over 14 volts now. Thanks a lot guys.
At some point i'll rewire the number 2 to a fuse box or horn relay. Tomorrow heading out to Tampa (100mi. away) for Southeast NSRA. Hope fully everything holds up. [IMG] [/IMG]
| '55 T-Bird 12 volt conversion | Sidn | Electrical | 4 | 08-29-2006 09:03 AM |
| 6 volt to 12 volt conversion? | ajcedar | Electrical | 7 | 03-09-2006 06:16 PM |
| 6 Volt or 12 Volt | 2000jack | Electrical | 2 | 02-09-2006 08:02 PM |
| 6 volt-12 volt battery question | MeEatsPigBrains | Electrical | 5 | 11-14-2005 01:49 AM |
| 9 volt to a 12 volt dist | 65Guera | Engine | 7 | 08-25-2004 02:33 PM |
