Alternator Light - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2008, 12:38 PM
wavy's Avatar
Last journal entry: Progress on Willys
Alternator Light
I have a 5.0 in a older truck and I am trying to install and alt light as a back up to my voltmeter. I have a 12 volt light in the circuit but it burns dim when the engine starts and runs, bright when the key is on and the engine is not running. In the schematic for this circuitry it show a resistor in this light wire. Is this resistor part of the Voltage Regulator or Alternator or is it in the wire some where. I show 14 volts at the voltmeter when the engine is running. If I rev the engine the light is still burning dim. Any suggestions?
Old 02-05-2008, 01:01 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I misunderstood the post the first time I read through it , I got lost at the alt. light part as a back up. Thought you were talking alternator, so the information was off base, real conversations are so much easier.
Old 02-06-2008, 05:31 AM
aka Duke of URL
You have what is referred to as a shunt ammeter and/or light. It must have the resistor.
Old 02-06-2008, 06:07 AM
wavy's Avatar
Alt light
What size resistor would work for this? Does it make a difference? The wire I am using is the wire in the original wiring diagram but it was cut on the firewall side of the loom so I am not sure what was under the dash or on the dash panel.
