Alternator over charging???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2009, 11:18 PM
New Member
I have a 69 camaro with a 383 stroker, the volts gauge is maxing out at 18 volts everytime the rpm is over 2000???? is somthing wrong with the alternator or somthing else?
Old 06-20-2009, 11:34 PM
it sounds like the regulator might be faulty, youll be boiling the electrolyte in the battery with that much overvoltage.
If its a bosch style alternator, the regulators are easily replaced and not very expensive to buy.
Old 06-21-2009, 07:36 AM
If I were you, I'd check the voltage on the battery with a volt/multimeter at >2000rpm to confirm your volts gauge or circuit isn't faulty before swapping the regulator. Just my two cents.
ssmonty
Old 06-21-2009, 08:08 AM
XNTRCI-T's Avatar
AKA Lee in KC
I had the same thing happen to me. Voltmeter was pegged at the high end. I didn't believe it and kept driving. Fried the MSD box and the battery. Took the alt in to a specialty shop and they said bad regulator.
Old 06-21-2009, 09:03 AM
T-bucket23's Avatar
Wiki Edits: 26
You will burn stuff up if you dont fix it. The regualtor is a fairly easy fix. You will need to take the alternator apart to replace it. Make sure you mark the case halves so you get it back together in the correct clocking.
Chet
Old 06-21-2009, 01:13 PM
New Member
Thats what i was thinking thanks guys!! battery was deff boiling after i parked it and checked.
Old 06-21-2009, 02:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Sounds like the regualtor is stuck. Change it out it a cheap part. Cole
72 Nova Charging System Help leejoy Electrical 14 05-01-2007 07:28 PM
charging issue? novadan Electrical 3 09-04-2006 12:01 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
charging system problems mmartin1872 Electrical 3 11-07-2004 01:51 AM
capacitor? no charging? 72Nova Electrical 7 01-07-2003 11:47 AM
