Doc here,
Sounds to me like you got an OBF..(Out of Box Failure) Not surprising since about 1 of 3 are bad now adays... To test it, just put a DVOM across the Battery Cables set for V X 50 or autorange, Take a reading, the Battery should be about 11.95 to 12.2 volts static, If not (like 10 or lower, you have a dead cell, replace the battery) NEXT run it, and let it idle..It should read 14.4 optimum, 13.96 is acceptable. If your getting lower than that, think warrenty.... OR you could go back to where you purchased the Alternator and instruct them to do a load/charge test on it..usually for free.. If under RPM load it suddenly "Slams in" you have a bad regulator..(I don't remember and am not a Ford guy at all, but I think all those are Externally Electronic Regulators. You Could have, If all else test out good, Bad Grounds, Set up a ground system this way: Run a properly gauged Ground cable from the battery to any handy bolt at or near the starter, From that same bolt get a Battery cable at the parts store, that has two 3/8 ring terminals on each end and attach it there and to the Frame. Next get some 10 gauge wire and ring terminals and run that from your bolt on the block to the Firewall, and another to the Alternator bracket or mount bolt. Next get some Wire Braid, (Radio Shack) and install braid from the radiator support to the frame, Fenderwells to frame , hood to firewall, Doors to door posts, gas flap to body, tailgate / Trunk to body. At each point the wire is grounded, Burnish ALL the paint and grease off to bare metal. Use a proper star-washer and lock. Use sheetmetal or Tech screws where no screws are available. It sounds like a lot of work, but after you assemble all the parts, it's only a few hours to do..and you'll end up with a system that will work reliably for many years to come..and can eliminate that from your troubleshooting list. Let us know what you find! Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Doc has seemed to cover it all but the thing that caught my eye is the oil leak,most com,on fords if it the water pump starts leaking it will have the same results,so i think you should try a new belt,and try to keep the oil off it,and see if it does any better,if knot i would try what doc said,
My,$0.02 Donald Stabnau |
alternator whoes
thanks for all the help i found out what he problem was it was a faulty reg and the fuse panel had some corrosion on some of the terminals after i cleaned all of this it went to working at idle but i did find one more problem the main power wire feeding the fuse panel is only 10 gauge for just about everything in the truck i am going to double it up so that it will have more capacity ......but i am still going to add the extrat grounds and clean with a wire brush the factory ones
I do have a question does anybody know where i can download the wiring diagram for my truck or atleast one close to it
Doc here, What Truck are we talking about here? Doc
Doc here,
Here ya go... ![]() ![]() Doc
