Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Alternator Regulator packs help!
Old 06-03-2010, 07:39 AM
The Flyin Wop's Avatar
The Flyin Wop The Flyin Wop is offline
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
Originally Posted by tylerwerrin
http://www.springhillautoelectric.co...&productId=462
if anyone is curious, this is the cheapest i've found for rectifier packs...
enjoy!
tyler
Just remember that diodes flow in one way only. The best way to check these is to use an ohmemter.touch the one lead to ground and one to the diode,then reverse the leads and do it again.If you get a reading on both test,its no good.
Good Luck,Paisano
