Alternator Switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2002, 05:15 AM
dollybud's Avatar
Question Alternator Switch
I've read that by installing a switch on the field of your alternator to turn off the drag during a run you can increase up to 35 HP. Any truth to this, and has anyone tried it?
Tom
Old 08-25-2002, 09:26 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Post
most of the drag i would assume would be coming from the pully. i dont see how shutting off the field would make a difference as far as power goes the alt. puts out power it doesn't use it so i don't see any advantage there, but i'm not a racer so they might know somthing i don't.
Old 09-08-2002, 10:55 AM
Old Fart
Post
Assuming you have a three wire Delco Alternator, the switch would have to be off prior to starting the car and many times the alternator will still self excite and start charging. I have seen these switches used on drag cars, including a friends, and have yet seen any proof that switching off the alternator does anything good. Most of the time it is going to do something bad. Most racers are running killer ignition systems which work much better with more juice. If you are running a 16 volt battery it won't matter whether you are running an alternator or not but if your running a 12 volt battery you will be much better off with the 13.5 - 14.5 volts that the alternator puts out.
I have seen homemade generator using Delco alternators powered by 3.5 horse Briggs motors so I seriously doubt you could ever see the difference in time slips.
Well you might. You could go slower without the alternator.
Al
<a href="http://www.AutoReWire.com" target="_blank">www.AutoReWire.com</a>
Al Campion
NORCAP Sales and Services
AutoRewire.com and Hot Rod Resins
P.O. Box 36
Topaz, CA 96133
209-481-6496
Old 10-04-2002, 06:06 AM
dollybud's Avatar
Smile
AL, check this site www.badasscars.com/techtips.
My alternator has 2 wires going to it in 1 push in terminal. Which is the field and what switch do you recommend if I decide to try this? Another dumb question....where do I hook up the positive side of a timing light when my battery is in the trunk? Starter? Thanks!
Tom
Old 10-04-2002, 12:37 PM
roys63's Avatar
Thumbs up
It is not worth adding a switch to shut down the alt you will allways forget to turn it back on, and MSDs like a lot of volts!The timing light can be hooked the the battery wire on the alt the big wire.
Old 10-06-2002, 04:50 AM
dollybud's Avatar
Smile
Thanks Roys63
Tom
