Alternator will not charge - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2008, 08:39 AM
Last journal entry: Albany Oregon Show
I first put on a used alternator that I know was good the last time I used it. Then I put on a new alternator, the exciter wire is hooked to the #2 tab on the alternator and the idiot light is hooked up. The charge wire goes directly to the battery. The charge wire has positive current verifying the battery connection is good, The exciter wire has positive power when the ignition is on, the idiot wire has negative power at all times. Now I know somewhere I am the idiot, but I just can't figure it out. This is a sbc in my Monza Drag car.
Bob
Old 07-28-2008, 09:58 AM
31 five window
Last journal entry: Moving along with patch panels.
Just because it is new does not mean it works. First step is go get them both tested so you know where you stand.This is normally free so all it costs is your time and you won't be fighting the wrong problem.Let us know after test and we will try to help with next step.
Old 07-28-2008, 10:07 AM
Alternator
Thank You
Will test it on Wednesday
Old 08-02-2008, 02:34 AM
justacertifiedtech's Avatar
or was that certifiable?
Last wiki edit: How to find an electrical drain Last photo:
Wiki Edits: 3
Right you are speedy
Always remember this
Rebuilt means it has already broken at least once.
Brand New means it has never worked before.
Old 08-04-2008, 07:35 AM
Alternator
You were right, both alternators were bad. Got a new on and tested it before I left.
Bob
1964 Impala SS - Battery Not Holding Charge 64Joker Electrical 8 07-28-2008 08:14 PM
Just a Dead Battery? 1quiknova Electrical 7 06-07-2006 07:04 PM
Body-shop Owners: How much would you charge ChrisMiddleron Body - Exterior 2 12-29-2004 11:11 PM
Turbo charge or super charge for a small block olds Andrew7dg Engine 2 11-12-2002 11:23 AM
no charge! deitwob Electrical 2 06-16-2002 06:46 PM
