alternator wiring help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2010, 05:25 PM
I am trying to wire up my alternator to fit into my car. Attached is a pic of my problem. The plug doesnt match the prongs they need to get onto. I have a 1972 Nova and the alternator was supposed to be a late 60's early 70's sbc alternator.
how do I make this work.
Old 05-13-2010, 05:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have a external regulator and horn relay, and you want to swap a internal voltage regulator equipped SI, use :
Old 05-13-2010, 06:31 PM
If I remember correctly, your 72 Nova was already equipped with an internally regulated alternator (the pic of the plug you drew shows this). The alternator you want to use is externally regulated...you don't have an external regulator in that car. So you're actually going "backwards" by trying to use an un-regulated alternator. Best solution is to turn that one in (or sell it) and get the right one.
Old 05-13-2010, 06:38 PM
Well when looking I have a external regulator and horn relay. I bought this car as a shell and have almost all done except the alternator and a few ends and odds. I have an alternator. The plug is what I am assuming, it might be for the HEI that I think was installed because the firewall is squished in to allow. There is also some wires at the end of the harness that have O ring terminals on them. I am sure that I need to pick up a service manual and find out what all of these wires are. I am just trying to fighure out what wires would go to what I have on the alternator I have as I want to use that alternator instead of buying another one.
Old 05-13-2010, 06:54 PM
Here's a pic of the two different alternators.
http://www.hotrod.com/techarticles/m.../photo_20.html
Old 05-13-2010, 06:58 PM
I think this is right.
Old 05-13-2010, 07:39 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
It sorta sounds like you might have the older style 10DN series alternator, similar to the one that came stock on my 66 GMC.
MOST of that type were only 37 or 42 Amp, and it sounds like the MAXIMUM output in this series was 63 Amps.
Does it look like this?
How to wire a 10DN series alternator
Old 05-13-2010, 08:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Original plug's R = #2 on the SI alternator and voltage regulator
Original plug's F = #1 on the SI alternator, "F" on the regulator.
If the SI-type alternator is what you're going to use- which it should be, IMHO- you can easily splice the two wires of the old original plug, into a correct pigtail for the SI, they are available in the "HELP" section of the parts store, and elsewhere. A common repair part.
You can also buy a kit to wire the alternator up by just plugging in the original plug to an adaptor, then the adaptor to the new internally regulated alternator. Go to: http://www.wiringharness.com/, click on FAQ, then select "I want to install an Internal Regulated Alternator".
Old 05-14-2010, 02:37 PM
I do have that alternator in the pic and my wires have been cut by the previous owner so I was thinking I had a different type of connection. What color wires should I be looking for?
Old 05-17-2010, 09:51 PM
Sounds like somebody may have changed it to a later alternator already. '72 Novas came with external regulators, at least mine (built Feb. '72) did.
Old 05-18-2010, 03:19 PM
the plug I thought was an alternator plug was not that. It looked like one tho was too short. The wires were cut that were to the alternator. Got that all sorted out, thanks for all of the help.
