Alternator wiring setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2008, 10:55 AM
Well i made a very very basic wiring harness for my little hot rod. It's basically all ford components.. The wiring harness is mostly all finished minus the part which the alternator connects. On the back of the alternator theres a positive and negative terminals where I'm pretty sure i can figure out where they go. But there are also 2 small prongs close together which i'm unsure where they go to.
I was thinking they might possibly go to a voltage regulator or something of that sort but i'm still partially unsure how even the voltage regulator wires in. I have the regulator which came on the truck that the alternator is out of so i might be able to get it all to work.. I was just curious if someone could help me with what the 2 prongs were on the alternator are for and if it is for a volt. regulator how would i integrate that into my wiring harness?
Old 07-04-2008, 11:24 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Is this what you have?
Good luck,
Rich
http://www.tffn.net/altwirng.html
or
http://www.explorerforum.com/photopo...4&ppuser=42004
Old 07-05-2008, 10:19 PM
Yeah i think the bottom one has the correct diagram. Thank you for your help.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
My 9inch rear end disc brake setup. 1937FordCoupe Suspension - Brakes - Steering 0 01-15-2007 06:01 PM
Is my Torque Converter too big for my setup ?? 74NovaRat Engine 15 02-01-2005 08:23 AM
TBI setup stfinney Engine 8 05-30-2003 02:43 PM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 10:53 PM
