Aluminium etch primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2010, 09:17 PM
I need to prime an aluminum radar arch on a 40' boat and need a top of the line etching primer for it. Does anyone have any recommendations on one? Thanks in advance for any help!! Matt
Old 05-08-2010, 06:32 AM
Last journal entry: 50 Ply wagon
There are a number of good primers meant for aluminum. I painted aluminum bodied dragsters and used a primer that was a yellow color. I forget the names but there are many out there. Go to your local automotive paint supply , they can help. remember to sand the aluminum with 400 wet to get the surface etched for adhesion of the primer.
Old 05-08-2010, 10:29 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Zinc Chromate
Old 05-09-2010, 08:15 AM
Old Fool's Avatar
SPI Epoxy will do a better job than etch primer
Old 05-09-2010, 07:54 PM
Thanks for the tip on the SPI epoxy, when I went to there website and read the tech on it though it said it was a self-etch primer which is what I am looking for... Thanks again,,, Matt
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Etch Primer SUCKS? Use epoxy primer? Arizona El Camino Body - Exterior 14 10-22-2009 09:51 AM
Etch primer holds strong. jcclark Body - Exterior 24 08-28-2008 11:32 AM
PPG Omni self-etch - what is it SUPPOSED to look like? Fat_46 Body - Exterior 14 09-30-2005 10:10 AM
Proper uses for acid etch primer? Rocket1 Body - Exterior 7 09-09-2004 08:50 PM
