Aluminum against steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 08:53 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Ive been reading some old threads lately, and Ive been thinking about a cool Idea I had.
Ive been cleaning and painting and what not around where the engine used to be in my truck. I want to put some aluminum diamond plate around the fenders and firewall just to dress it up some. Id like it to be aluminum so I can keep it polished up, and it won't be under a lot of stress so scratches won't be a big deal.
But what bothers me is the corrosion it causes with the steel of the truck. I don't want to put a peice of plywood behind it but would maybe some plastic washers between the aluminum and steel would work where I put the bolts? or some type of rubber strips between the two?
Any thing else I could do to prevent my truck from turning into a rust bucket?
Brad
Old 02-06-2006, 09:22 PM
BadS10's Avatar
fenders
you are on the right track with the washers or rubber stripping.anything to keep the two separated will work.the only other problem is the heat under the hood could cause the aluminum to dull faster you might consider possibly going with a stainless fender
Old 02-07-2006, 11:20 AM
Gone fishin'
Wiki Edits: 2
Thanks man.
So I guess if I just go to lowes or home depot and buy some cheap rubber weather seals for windows and just stick it to the back of the aluminum it should be fine. cool
Brad
Old 02-07-2006, 11:51 AM
astroracer's Avatar
How are you attaching the aluminum? Bolts? Screws? Isolating the panels will be impossible if you are hard mounting them with steel fasteners. No matter how much rubber you put between them there is still a ground path through the fasteners...
I wouldn't worry about it. Modern day cars use aluminum and steel in mixed assemblies all day long with no problems. If you keep the aluminum polished I doubt you will have any problems with it... It will not cause your truck to rust any faster.
Mark
Old 02-08-2006, 12:26 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Lowe's has a selection of nylon bolts and such also. Since there will be no stress on the panels that would be a good solution.
gluing aluminum to painted steel? ye12 Body - Exterior 2 01-28-2010 03:33 PM
galvanic corrosion, aluminum on steel? rlackey Body - Exterior 22 05-20-2005 08:57 PM
steel -vs- aluminum flywheel fat50 Engine 12 01-04-2005 04:16 PM
Bonding Custom Aluminum Panels To Steel bmech211 Body - Exterior 2 12-16-2003 09:49 PM
aluminum to steel ghastly53buick Body - Exterior 6 10-13-2003 07:28 PM
