Aluminum block, cracked deck. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-17-2012, 06:42 PM
How about a hard-fill? I'm not sure how you could isolate it to just that spot though. Hard-fill is what a lot of builders do to make the block stronger and to resist deflection. It's basically a concrete-like iron mix that you pour into the water jackets and let harden up. It doesn't allow the cylinders to deflect at all. Most of the cooling in your engine takes place in the cylinder head. Having coolant flowing through the head is a must.
http://www.summitracing.com/parts/HNH-860228/
cracked block or cracked heads 4x4Chevy Engine 12 01-18-2012 03:41 PM
cracked block can a block be welded chevy bb 572 Engine 5 06-16-2009 11:16 PM
Block Cracked 2wheeler Engine 9 05-20-2008 09:29 AM
cracked block kenneth29 Engine 9 03-21-2006 08:59 AM
Cracked aluminum valve cover 66Caprice Engine 1 07-17-2004 12:32 PM
