Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Aluminum or cast iron sbc heads????
Old 03-25-2010, 08:44 PM
automotive breath's Avatar
automotive breath automotive breath is offline
The primary reason I run aluminum heads is because they are easy to weld
on. I have seen heads damaged so bad that an entire combustion chamber
had to be replaced including the rocker bosses and spring pads. When it was
done you could hardly tell they were worked on.
