Aluminum or cast iron sbc heads???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2010, 08:11 PM
All you horsepower fiens, I'm ready to buy my heads for a 6-71 blown 383 stroker. I know aluminum is lighter and will completely disburse if the engine over heats or i spray to much nitrous. I'm learning that cast iron will last longer for my set up and i wont have to worry about melting and should be safe with nitrous. Can everybody reply and give me thier opinion?
Old 03-25-2010, 08:44 PM
automotive breath's Avatar
The primary reason I run aluminum heads is because they are easy to weld
on. I have seen heads damaged so bad that an entire combustion chamber
had to be replaced including the rocker bosses and spring pads. When it was
done you could hardly tell they were worked on.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
SBC aluminum heads g-bar99 Engine 14 06-08-2010 02:56 PM
Mig Brazing Cast Iron Cylinder heads Tommurphy73 Engine 3 09-05-2007 08:55 PM
SBC aluminum heads brainsboy Engine 3 04-26-2006 08:24 AM
iron performance heads for SBC LD85 Engine 39 05-03-2003 07:44 PM
