Aluminum Corvette heads on SB 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2008, 12:50 PM
I am wondering if having my 10088113 aluminum heads machined to accept 2:02 valves to install on my SB 400 engine is a good idea or waste of cash. I plan on 5.7 rods and a roller cam. I know the pistons might be harder to find for these 58cc heads with the longer rods, but not as hard as if I use 6' rods. I want the truck to run on pump gas. Any advice would be much appreciated.
Old 07-26-2008, 12:59 PM
You will need to drill the heads for the extra steam holes that a 400 requires. It can be done using a 400 head gasket as a guide.
That said ... I would sell the Corvette heads and buy a GOOD set of aftermarket heads with the 2.02 valves already in them. By the time you buy the larger valves and have them installed in your heads ... PLUS the money from your old Corvette heads ... it will BUY the new, better flowing heads.
Old 07-26-2008, 08:43 PM
327NUT's Avatar
Personally I wouldn't screw around installing the larger valves, #1 ... for the reasons "Deuce" eluded to and #2 .... the smaller valves will build a little better low end grunt. I would just have a good valve job done and match the piston/rod assembly to compensate for the added compression of the smaller combustion chamber.
Old 07-26-2008, 10:04 PM
What do you want to do with it?
What's your goals?
What's your budget?
What's the weight, transmission, gears, tires, etc.?
Old 07-26-2008, 11:04 PM
My goals
What I would like to do is build a fast street/strip engine with a limited budget. The head work wasn't supposed to be that expensive I was told under $300. but I may have misunderstood. If I have a stock bottom end 400 and I just left the heads at 1:94 with a valve job and bolted them on (steam holes drilled of course) and added a nice cam would the motor run fast? the 58cc chambers should keep the compression under 11:1 since the stock comp was 8.5 or 9 to 1, am I thinking correctly? Would it be worth going with a roller cam in this application. It will be going into a 72 C10 long bed. Thanks to all offering advice
Old 07-27-2008, 01:55 PM
TorkMonster400's Avatar
uninteresting default message
Last journal entry: A couple of pics of the car
Wiki Edits: 4
Has any one else had any problems with these same heads not mounting up plum with a RPM airgap intake? I have a Gap on the block that is about .150 between the block and the intake, these heads have a lip around the top witch is catching the intake. Think I can grind it down a little?
I think these heads are going to be great, yes the 58cc is something to think about but they have -22cc and -30cc KB pistons for a good price. I agree with the LT4 upgrade and then port them a bit.
I think If I remove just a little around the yellow part in the pic I can fit? any comments? or could this just be that I had no gaskets on the block or heads or intake just kinda puttin it there to see what it looks like sort of thing.
Name:	DSCN0703 fix this.JPG
ID:	31483   Click image for larger version
Name:	DSCN0489 fix this.JPG
Old 07-27-2008, 04:20 PM
NOT trying to hijack this thread.
Maybe there should be an new thread for this.
What heads are they?
The block to intake clearance is fine, RTV fills the gap nicely.
If your intake doesn't fit the heads, is it designed for those heads?
LT4 stuff doesn't fit other Gen engines, do they? Isn't the LT1/4 reverse flow?
Old 07-27-2008, 05:06 PM
This isn't a very good head, the ports don't flow well on a 350 and there isn't enough meat to open them up much. Large valves are solving a non issue. The problem is getting mixture thru the port. The valve size isn't the critical issue with these, so spending the money to make them bigger won't buy anything.
Don't get me too wrong, these heads an OK on a mild street 350, they're a great addition to a 307, 305, 283; but that's as good as it gets. They're woefully short on port capacity for a 383. Use 'em if you must for the short term, but don't spend money trying to make a silk purse out of a sows ear; cause it's just going to be a shiny ported, big valved sows ear. Save your hard earned dollars for some good heads out there in the future somewhere. If you must use these to get going, spend the minimum time and money to do so.
Bogie
Old 07-27-2008, 09:09 PM
Originally Posted by 327NUT
Personally
"I am going to be really categoric about this that to make best low speed torque the engine needs the valves to be as big as can be crammed into the space available." DAVID VIZARD
Old 07-28-2008, 11:00 AM
It that's what Mr. Vizard said, he's WRONG!
Torque in the mid range (which is really mid range horsepower) is highly dependent upon incoming and out going gas velocity. The impact of large ports and or large valves reduces these velocities which in turn reduces both fill turbulence and mixture density inside the cylinder which reduces torque which translates into horsepower, which is what does the work.
The original valve size with these ports, especially on a 383, will hit really hard in the mid revs, as Chevrolet originally intended that you feel with the TPI L-98 engine. But the upper RPMs will go soft, a lot like using a 305 head on a 350.
The 113 head doesn't have the port volume or shape to feed a 383 above 4500-5000 RPM and the head doesn't have enough material to really port these to feed a 383 above those RPMs. Therefore, the solution to feeding the cylinder is time rather than size dependent. That's to say the head will be responsive to a longer duration cam rather than big valves, given you really can't do a enough with the ports to feed a larger curtain area of a bigger valve. The best of pro-ported 113 heads I've ever seen, are smoked by set of out of the box Vortecs. What the home porter can do without a lot of knowledge and a flow bench will be woefully short of what TPIS can do unless they stumble into more luck than the average bass fisherman.
Knowing this, it is my recommendation that he minimize effort and expense on the L-98 heads, get the motor running since he stated he's short on cash, and drive the thing while saving his nickles and dimes for a set of DARTS, AFRs, GM Fastburns, even iron Vortecs. And I'm being kind, Frankly I wouldn't spend a dime on those 113's for a 383, I think long and hard for a 350 b ut would be more than willing to stick them on top of a 305. He'd be way ahead to put 'em for sale on e-Bay, take the money add that to what he would've spent on a valve job and buy a decent set of modern heads. In the end, The cost of new heads won't be much different from fixing the 113's, while the performance on a 383, in all aspects, of a better set of heads will be amazing.
Bogie
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
781 heads or aluminum heads bigwildgrin Engine 2 03-07-2006 08:25 AM
SBC 400 Steam Holes w/L-98 Heads?? ezobens Engine 17 02-24-2006 01:50 PM
Dart BBC Aluminum Heads jakejake1966 Engine 6 02-23-2006 07:27 PM
Aluminum heads/ any disadvantages? laitch Engine 15 01-17-2003 07:57 PM
