aluminum flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2005, 05:54 AM
aluminum flywheel
I'm building a 406 for a 87 corvette/ 4+3 trans (4 speed manual-auto over) would anyone suggest an aluminum flywheel if so where can I get an externally balanced one
Old 07-29-2005, 07:05 AM
I assume you mean a flex plate (used with auto tranny. Fly wheels are used with manual tranny). Because of the increase fatigue cracking qualities of aluminum, I would never use one on a flex plate (name implies a certain amount of flexing which would be death of aluminum). Now if you mean fly wheel, then the soft aluminum would not make a satisfactory wearing surface for the clutch plate. Either way, I would not consider aluminum.
Trees
Old 07-29-2005, 07:29 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Trees
They have steel insert's for wear protection. And they are replacable. I still wouldn't for the street only, or even some drag only. Low moment of inertia makes for a poor shifting/launching car.
Old 07-29-2005, 09:18 AM
THE 4+3 is a manual trans
Old 07-29-2005, 09:21 AM
Last journal entry: PICTURE TEST
flywheel
I personally would not run a aluminum flywheel in your application...
Keith
Billet steel flywheel or aluminum? 70bird Transmission - Rearend 3 03-27-2005 06:31 PM
steel -vs- aluminum flywheel fat50 Engine 12 01-04-2005 03:16 PM
use of aluminum flywheel on the street..thoughts 357f-150 Transmission - Rearend 11 12-23-2004 12:10 PM
gains from an aluminum flywheel. Super Chevy Engine 10 02-25-2004 02:14 AM
Aluminum flywheel Camaro2Fast4u Transmission - Rearend 1 02-04-2003 09:17 PM
