Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Aluminum Fuel Line ?
Old 04-08-2013, 06:23 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Aluminum fuel line is fine. There is virtually no pressure, it's fairly corrosion resistant, is very easy to work with and is much less expensive then stainless. While I didn't use it in the current car have on previous with great success. Another and possibly better alternative are the 5/16 and 3/8 inch steel brake/hydraulic lines which you can get in lengths to at least 6 feet or longer rolls. It can be easily bent, double flare fittings used as well. Any auto supply house will have whatever lengths you need
Irelands child
