Aluminum Fuel Line ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-02-2013, 06:07 AM
Irelands child's Avatar
Originally Posted by 35terraplane View Post
Dave some s/s is magnetic, none of the 300/ series. There are some 400/ seies is, such as 416 is a little, then some of the oddball stuff that is also.
Bob
Yep, Bob I am aware of that. It's generally a test whether the part 'leaps' to the magnet(regular steel) or just barely hangs on. I'm normally using a rare earth magnet from a dead 'puter hard drive when I do my 'testing' so they are strong. Most 316 SS washers (from McMaster Carr McMaster-Carr ) I've been using are slightly magnetic. I have some general use tie wire that's that way as well.
Dave W
Irelands child
  #17 (permalink)
Old 05-03-2013, 01:50 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by NEW INTERIORS View Post
All I ever use is the same clamps as tech posted..I use them on a lot of things, Brake lines,hoses,fuel lines, and so on.. Never had one go bad yet...
REALLY nice!
The Following User Says Thank You to techinspector1 For This Useful Post:
NEW INTERIORS (05-03-2013)
  #18 (permalink)
Old 05-03-2013, 05:53 PM
life is a temporary assignment
Originally Posted by techinspector1 View Post
REALLY nice!
Thanks tech..
I try my best..
  #19 (permalink)
Old 05-04-2013, 04:38 PM
Let's look at it this way;
Airplanes use aluminum fuel lines, and sit on the ramp, out in the weather for months on end, without even being started.
They don't have any trouble with them, just the rubber hoses have a "life limit" placed on them. And must be replaced after a period of time regardless of condition. There are bends in the lines, and flared fittings. But the flare is not as flat as the flare used in the auto industry. also not a double flare.
Granted; 2024-t3 aluminum "work hardens" but there's no need to use that alloy in a car. There are softer versions such as 2024-t0 which hasn't been heat treated, and is much easier to work with.
  #20 (permalink)
Old 05-11-2013, 11:06 PM
1971BB427's Avatar
I've used steel and aluminum both on builds, and aluminum is a lot nicer to work with. I use insulated clamps, and in any area where it passes through holes I split rubber hose and slip it over the line and tie with nylon ties to protect it from vibration or physical harm.
Never had a problem with aluminum if I do my part right.
aluminum fuel line schatzy Engine 9 06-25-2007 07:20 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 09:50 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 11:59 PM
Aluminum fuel line??? fireforsin Engine 7 10-15-2004 11:55 PM
Aluminum fuel line vs. rubber near engine McDeuce Engine 1 02-16-2004 07:39 PM
