Aluminum Fuel Line ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 03:02 PM
454 Rattler's Avatar
NEVER SATISFIED !!
Anyone have a reason that I should NOT use Aliminum fuel line in a Street Rod ?
Bear in mind that this car sits unused for several months over the winter.
THANKS !!
454 RATTLER
Old 04-02-2013, 03:22 PM
Banned
aluminum just does not compete with stainless , yes it is cheap, but it does not take bends well and after you unwind what you need you just can not make it run a strait line. also when you try to flare it, it does split fast. Spent the extra cash and use stainless. And have a job well done.
Old 04-02-2013, 03:52 PM
35terraplane's Avatar
I don't think you need stainless, besides some of that will split as fast as alum. just plain old steel brake line will work great, you can use a bender on it, it will flare good, and run straight, plus you can get it at any parts store.
Bob
Old 04-02-2013, 04:09 PM
Banned
they make a line out of a copper/nickle combo.. thats as easy to work with as alum without the flare splits and ethnol screwing with it..
AGS Company - NiCopp Products
cheaper than s/s and not the p.i.t.a. that s/s is to bend/flare/ and doen't rust
Old 04-07-2013, 10:10 PM
bentwings's Avatar
bentwings
I used aluminum tubing and AN fittings on my car ans have not had any problems. I have to let it sit over the winter and don't see any problems with that either.
I would be best if you use a flex line on both sides of an electric fuel pump or the pump sound will transmit thru the frame.
Old 04-08-2013, 06:23 AM
Irelands child's Avatar
Aluminum fuel line is fine. There is virtually no pressure, it's fairly corrosion resistant, is very easy to work with and is much less expensive then stainless. While I didn't use it in the current car have on previous with great success. Another and possibly better alternative are the 5/16 and 3/8 inch steel brake/hydraulic lines which you can get in lengths to at least 6 feet or longer rolls. It can be easily bent, double flare fittings used as well. Any auto supply house will have whatever lengths you need
Irelands child
Old 04-08-2013, 07:55 AM
NEVER SATISFIED !!
Thanks, guys ! I knew I could count on you.
454 RATTLER
Old 04-08-2013, 02:55 PM
BigMo's Avatar
Used it for years on many a high powered street/strip car and had no problems, however, ya gotta use grommets at every pass-through cause it will vibrate and wear to failure......just sayin
Old 04-13-2013, 06:38 PM
ran nice anodized aluminum before ...no trouble
Old 04-20-2013, 12:55 PM
techinspector1's Avatar
Wiki Edits: 326
The key to longevity with any fuel line is to secure it so that it cannot flex. Here is an example of an Adel clamp that I might use with 1/2" aluminum line. I'd use one every 12" or so along the frame rail or bottom sheet metal of the car.
Mr Gasket ADEL Hose MOUNT CLAMPS - JCWhitney
Old 04-20-2013, 02:35 PM
life is a temporary assignment
All I ever use is the same clamps as tech posted..I use them on a lot of things, Brake lines,hoses,fuel lines, and so on.. Never had one go bad yet...
Old 04-22-2013, 03:57 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
I like the cushion clamps too and Tractor Supply stocks them in various sizes.
The Following User Says Thank You to 1930u For This Useful Post:
NEW INTERIORS (04-22-2013)
Old 04-23-2013, 05:31 AM
I've used some from Home Depot - but there is a caveat to what I use. They have to be stainless and not all from sources like HD or Tractor Supply are. Hopefully it say SS or else find a magnet to check (some SS are mildly magnetic)
Dave W
Irelands child
Old 04-23-2013, 07:05 AM
NEVER SATISFIED !!
I went with a steel line and the cushioned clamps this time.
I have used the aluminum line on my 427-L88 Camaro street car/JR stock racer back in the day.
Thank you guys for your replys. It's really nice to know I have someone to lean on when I have questions.
454 RATTLER
Old 05-01-2013, 09:43 PM
Dave W
Dave some s/s is magnetic, none of the 300/ series. There are some 400/ seies is, such as 416 is a little, then some of the oddball stuff that is also.
Bob
aluminum fuel line schatzy Engine 9 06-25-2007 06:20 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
Aluminum fuel line??? fireforsin Engine 7 10-15-2004 10:55 PM
Aluminum fuel line vs. rubber near engine McDeuce Engine 1 02-16-2004 06:39 PM
