aluminum fuel lines ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2006, 05:40 PM
Vortech 4.3's Avatar
jack of all trades
hello
i am putting together a mpfi setup on a manifold. and i was thinkin it would look good to use aluminum fuel lines to connect the fuel rails, and to the regulator, and to a block that would connect to the lines going to the rear. but i have never worked with aluminum fuel line before, so i don't know how it acts. like bending it, how tight can it be bent ? how good are the fittings ? stuff like that, anything.
thanx
and pics would be
Old 02-12-2006, 06:47 PM
73oldsman's Avatar
Get a tubing bender, such as this; http://cgi.ebay.com/1-4-5-16-3-8-TUB...ayphotohosting, and practice on some tubing and then go for it!
Old 02-12-2006, 07:46 PM
The tubing is easy to work with. I work with the fittings every day as an aircraft mechanic. As long as they're started straight they work good, last a long time. Just as it takes some practice to fit exhuast pipes or roll bars it takes some practice to the more complex pieces to look good.
Old 02-13-2006, 06:41 PM
jack of all trades
thanx guys.
i already have that bender. can i get a link to the kind of fittings need ? or are they flared just like steel lines ?
Old 02-13-2006, 06:53 PM
302 Z28's Avatar
Aluminum fuel lines can be flared just like regular plumbing lines at a 45 degree angle. Or they can be flared at a 37 degree angle for AN fittings. Also you can use standard compression fittings and not have to flare at all.
Jegs or Summit Racing will have everything you need. Look up Earls or Russell on either site.
Vince
Old 02-13-2006, 08:00 PM
73oldsman's Avatar
http://www.jegs.com/webapp/wcs/store...0019&langId=-1 and http://www.russellperformance.com/au...fuel_lines.htm
Old 02-14-2006, 08:05 AM
I had some problems with aluminum tube cracking open. So, I went with stainless tube and compression fittings and have been very happy with it.
Old 02-14-2006, 08:27 AM
302 Z28's Avatar
I would not use aluminum for a pressurized (fuel injection) system.
Vince
Fuel Injection Fuel line Plumbing william27103 Engine 9 06-10-2011 05:22 PM
Aluminum fuel line vs. rubber near engine McDeuce Engine 1 02-16-2004 06:39 PM
Fuel Line's JimmyL Engine 8 09-24-2003 08:59 PM
questions about fuel system for a 434 small block chevy tony350ss Engine 4 08-27-2003 11:02 AM
Fuel lines Tom S Engine 6 07-29-2003 05:30 PM
