aluminum head bolt question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 11:25 PM
im about to install a set of aluminum brodix heads on my sbc. can anyone tell me if i need to use washers under the bolts? the bolts are new and the head of the bolt looks like a washer is built in. <-----does that make any sense. also can someone tell me what the white stuff in on the threads of the bolts? is it a lube of some sort or is it a sealer also should i use rtv sealer on the bolts. thanks in advance i wouldnt have even got this far if it wasnt for some of your help thanks again
Old 10-26-2010, 12:40 AM
F-BIRD'88's Avatar
Yada Yada Yada
Ya you need the hardened head bolt washers. Ya its thread sealer.
Old 10-26-2010, 12:43 AM
ericnova72's Avatar
More for Less Racer
The white stuff is pre-applied sealer, if it has really dried out you may want to remove it and use a fresh sealer.
With aluminum heads you always need a washer in order to prevent galling the head surface, even if the bolt has a built-in washer head. The washer acts as a bearing, it is a hard surface for the bolt head to seat against so it doesn't tear up the aluminum. Put some lube between the washer and the bolt underhead surface to get a true torque reading when assembling.
Old 10-26-2010, 02:23 AM
SSedan64's Avatar
GM does sell & use a Head Bolt Kit with the flange for use on Iron or Aluminum Heads but, it's best to use a washer.
GM #12495499 >> http://www.gmpartsdirect.com/ I've seen these used on a few Al. Head GM Crate motors without washers.
Old 10-27-2010, 09:06 PM
thanks for all the resposes
i got the correct washers for my bolts.
Head bolt question truckboy61 Engine 5 03-30-2010 04:31 PM
Stripped 454 head bolt hole, ideas? RamAirZ Engine 4 11-19-2009 06:49 PM
sbc helicoil head bolt hole GMR Hotrodding Basics 20 08-14-2009 06:27 PM
head bolt question jjpodlas Engine 4 10-14-2007 05:06 PM
Quick vortec head question w/perimeter bolt covers? Blazin_Jason Engine 15 03-18-2007 10:59 AM
