aluminum head id? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2006, 05:32 PM
aluminum head id?
i have these alum heads we got at a swap meet in daytona turkey rod run.
pick the heads up for $100 not bad at all. i was told they came off a 98 corvette. i treid looking these heads up on mortec and nastyz28.com but couldnt find them. the head number is 12552203 the # came from where the rockers are. i might off got the #'s wrong so i'll check again. what would these heads be worth? but if any one knows what these heads it will help. thanks for your help!!
Old 04-13-2006, 07:41 PM
BOBCRMAN@aol.com's Avatar
They are apparently worth $100.00.. These heads ONLY fit reverse flow SBC motors. You will first notice the odd bolt pattern and then the fact that they have no water crossover passages. Makes their use very limited. Like to reverse flow Corvettes and some Cop cars and Buick barges!!
351W heads, how to identify from 289/302 RAW Engine 22 01-28-2010 04:54 PM
head gaskets for aluminum heads bpnoble Engine 5 12-04-2004 06:27 PM
Prepping aluminum BarryK Body - Exterior 3 06-13-2004 09:07 PM
Head Castings 69 chevelle SS Engine 1 10-05-2003 06:49 PM
1BAD80 or anyone BERN Engine 3 04-17-2003 08:11 AM
