Aluminum Heads ???? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-25-2011, 08:20 AM
lg1969's Avatar
Google "Tunnel Ram 406"
For amount you are spending on double hump heads to fix, a few hundred more get Edlebrock. If money is no object then AFR's.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Aluminum heads HELP! 1fast62 Engine 9 02-15-2011 06:50 PM
383 aluminum heads thefloyd1973 Engine 2 05-13-2008 10:57 AM
Which Aluminum Heads, SBC Sinister Engine 24 03-12-2008 06:00 AM
Aluminum L98 Heads My383 Engine 2 04-24-2005 05:43 AM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 05:46 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
