Aluminum Heads ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 06:50 PM
Aluminum Heads ????
I have a 70 Vette that needs a valve job. I have decided to just replace the old double humpers with a fresh set of aluminum heads but there are so many out there
I will be running a half lift solid tappet cam
Can anyone suggest the best set for me and what cc should I be looking for
It is a weekend car seldom driven
Thanks
Old 04-21-2011, 06:59 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What is a "half lift solid tappet cam"??
Chamber volume depends on what c.r. you're working toward.
Here's one of many calculators available.
Old 04-21-2011, 07:03 PM
He probably means a "half inch" lift cam, but I've never heard it put quite that way before.
Old 04-21-2011, 07:06 PM
Onefunponcho's Avatar
Everyone seems to be raving over the Air Flow Research heads..... But they are expensive. You will be paying as much for a set as all the non chevy guys have been paying for their heads for years
You'll need to tell everyone about your setup in greater detail before they will be able to really be specific though
Old 04-21-2011, 07:32 PM
Last journal entry: Paint
You can't go too wrong with AFRs they are like a work of art.
ID:	54574   Click image for larger version
Old 04-21-2011, 08:49 PM
techinspector1's Avatar
Wiki Edits: 326
If I were you, I might consider the entry level aluminum heads from Edelbrock, the E-Street head. 900 bucks for the pair, ready to bolt on. Use a RPM intake, 750 carb and 1 5/8" long-tube headers.
http://www.edelbrock.com/automotive_..._estreet.shtml
http://www.summitracing.com/parts/EDL-5073/
http://www.summitracing.com/parts/EDL-5089/
I know you're going to tell me that an RPM intake won't fit under your hood, to which I will reply....What Hood?
Old 04-21-2011, 10:18 PM
302 Z28's Avatar
Edelbrock
Vince
Old 04-21-2011, 10:38 PM
bentwings's Avatar
bentwings
I have Edelbrock rpm. Hard to beat for the street and price. Quality product.
Old 04-23-2011, 05:23 PM
Hood
I know you're going to tell me that an RPM intake won't fit under your hood, to which I will reply....What Hood?[/QUOTE]
Sad to say I still have a sbc hood on now. But I am looking even tho this has broken me
Old 04-23-2011, 05:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Edelbrock And the RPM intake just run the stock drop base filter housing, That's the problem you can't run just any air filter set-up on those cars ask me how i know .
Cole
Old 04-23-2011, 05:36 PM
Wiki Edits: 326
Cut it for clearance and glass a bubble on it. You're gonna need a 14" X 3" air filter anyway. Make it 14" X 4" while you're doin' it.
Old 04-24-2011, 12:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
In the off chance the engine is original, hang on to the part$ you remove.
Old 04-24-2011, 05:41 AM
alloys
from my own experience just put a set of edelbrock e streets on ford powered 32 roadster good value, performance wise not much different cause cast heads had big valves ported, but big weight difference regards pedro
Old 04-24-2011, 04:41 PM
1984 C-10 383 SBC
Brodix IK 200, 64 cc.
Old 04-25-2011, 08:20 AM
lg1969's Avatar
Google "Tunnel Ram 406"
For amount you are spending on double hump heads to fix, a few hundred more get Edlebrock. If money is no object then AFR's.
Aluminum heads HELP! 1fast62 Engine 9 02-15-2011 06:50 PM
383 aluminum heads thefloyd1973 Engine 2 05-13-2008 10:57 AM
Which Aluminum Heads, SBC Sinister Engine 24 03-12-2008 06:00 AM
Aluminum L98 Heads My383 Engine 2 04-24-2005 05:43 AM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 05:46 AM
