Aluminum Heads & Cast Iron Intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2008, 10:05 PM
I have never seen anyone with a cast iron intake mounted on an engine outfitted with aluminum heads.
Anyone ever seen this done?
Anyone here know what the expansion rates are between the 2 metals???
I doubt it but I thought I shoot the moon & ask...
Old 09-15-2008, 10:51 PM
Jmark's Avatar
As long as you use the "Print-o-seal" gaskets by felpro, it's not a huge deal. Similar to cast heads and aluminum intake, cept the temps in the heads affect the aluminum a little more.
Mark
Old 09-16-2008, 09:24 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Its been done by the factory before. Many of the 4 and 6 cylinder aluminum headed GM engines from the early 60s were this way, and a few of the early aluminum headed Mopar Wedges had iron intakes.
Old 09-16-2008, 09:37 AM
kleen56's Avatar
A friend of mine did it on his engine but only because he didn't have enough money for an intake at the time. He used the gasket as JMark stated. It worked but really defeats the purpose of having expensive aluminum heads. Once he got his aluminum manifold, the engine came alive! In some cases the porting on the cast intake is smaller than that of the aluminum heads, whereby an aluminum intake can easily be port matched to the heads increasing horsepower and performance. Aluminum intakes are pretty inexpensive and easy to find. If I recall, my friend stated that his engine ran cooler with the cast iron manifold.
Cast or Aluminum Heads for Alcohol S10 Racer Engine 1 12-25-2007 04:50 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
small block ford cast iron heads k-star Engine 20 12-10-2005 08:35 AM
Ceramic coating aluminum heads AngliaBob Engine 12 09-26-2004 03:04 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 12:56 PM
