Aluminum heads, iron block, what head gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2010, 11:18 PM
Hey guys I'm wondering what kind of head gasket you need to use on a SBC build with aluminum heads? I have heard you need to use to MLS (multi-layer steel) gaskets to allow movement between the two disimilar metals but the problem is I need a gasket that is about 0.020" compressed thickness and can't find any MLS gaskets of this compressed thickness. Is there any other type of gaskets that work (maybe the expensive copper gaskets) or does anyone know of where I can find the right gasket in around a 0.020" compressed thickness?
Thanks,
keith
Old 09-20-2010, 11:36 PM
ericnova72's Avatar
More for Less Racer
Your not going to find one. GM has an .028" thick, that is as close as you are going to get. Smarter move is to deck the block to allow a correct decent thickness aluminum head compatable gasket, side benefit is you get a nice perfectly flat surface in the bargain, a big plus with aluminum heads.
Old 09-21-2010, 12:31 AM
techinspector1's Avatar
Wiki Edits: 326
The other benefit you get, if you cut the decks by registering off the main saddle, is that the decks no longer slope front to rear or rear to front and you stand a better chance of making the same static compression ratio on all 8 holes. Oh yeah, and the intake manifold stands a better chance of sealing up at the head ports.
Old 09-21-2010, 07:45 AM
Cometic will make you a gasket. Expect to pay about $80-100 each.
Aluminum Heads scenario of potential problem of cause of oil consumption (long) y2k600f4 Engine 37 09-14-2009 05:22 PM
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
Need help with head gasket on 289 with 302 heads 1967stang Engine 3 10-19-2003 07:01 PM
