Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Aluminum Heads for Mild 327?
Old 08-13-2012, 07:40 AM
cdminter59 cdminter59 is offline
Check out this deal at
Amazon Amazon
Look to the right under more buying choices for 534.20 each.RHS made by COMP Cams. These would be great heads. On Comp Cams Camquest this HYD cam XE-274H 490 lift 230/236 duration at .050 with these heads on a 327 CID will make about 372.9 hp and 383.4 lbs. of torque. Even more with a 750 cfm carburetor.
