Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Aluminum Heads for Mild 327?
  #22 (permalink)
Old 08-22-2012, 09:15 AM
cdminter59 cdminter59 is offline
327 cam selection
Lunati 50143 - Lunati Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com Howards Cams 113215-10 - Howards Cams Retrofit Hydraulic Roller Camshafts - Overview - SummitRacing.com Howards Cams 111145-12 - Howards Cams Retrofit Hydraulic Roller Camshafts - Overview - SummitRacing.com Lunati 60112 - Lunati Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com Lunati 501A3LUN - Lunati Retrofit Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com I would use a 355:1 rear gear. I had a 92 Camaro and that the gear that was in it. Had good pickup from a standstill and good top end too. If you are not worried about correct #s a 8.5 rear from any 72-75 Nova and 76-79 V8 Nova is a direct bolt in. They are called the big 10 and have a 30 spline pinion and 28 or 30 spline axles. Just as tough as a 12 bolt.
