Aluminum Heads for Mild 327? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-04-2013, 12:31 PM
vinniekq2's Avatar
327
Originally Posted by 1Gary View Post
To be honest when I skimmed over this thread and saw 327 and aluminum heads the first thought that enter my mind was lean on the compression,build a RPM capable bottom end,cam it to buzz to the moon with heads accordingly to breath.Remember the Camaro's are heavy cars that need that to move them.
I would like to have seen one size bigger cam and a solid roller.That would make a lot more power
  #47 (permalink)
Old 04-04-2013, 01:25 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Well we are alot like everyone else in one sense.Pretty good at spending other people's money.LOL!!.
  #48 (permalink)
Old 04-04-2013, 05:30 PM
techinspector1's Avatar
Wiki Edits: 326
You know, sometimes you just hit a sweet spot and the OP has done just that with this combination. This little motor makes some very pretty hp and torque curves. Any of you guys who want a 327 that will pull away strongly from a stop and still haul the mail at the top, should emulate this combination. I used the flow numbers from the Stan Weiss site to run this Sim.....Dynamic Compression Ratio of this combo is 8.428:1.
RPM HP TORQUE
2000 138 363
2500 177 371
3000 226 395
3500 280 421
4000 331 433
4500 375 435
5000 407 428
5500 425 406
6000 415 364
Peak volumetric efficiency 92.7% @5000
Peak BMEP 198.7 lbs @4500
Maximize the combo by retarding the cam 4 degrees and pick up 9 hp and 4 ft/lbs of torque. 650 is just the right amount of carburetor.
Good job SSCamaro_510.
The Following 3 Users Say Thank You to techinspector1 For This Useful Post:
1Gary (04-04-2013), sscamaro_510 (04-04-2013), vinniekq2 (04-04-2013)
  #49 (permalink)
Old 04-04-2013, 05:58 PM
vinniekq2's Avatar
techs post confirms what we all agree on
  #50 (permalink)
Old 04-04-2013, 09:24 PM
sscamaro_510's Avatar
RPM HP TORQUE
2000 138 363
2500 177 371
3000 226 395
3500 280 421
4000 331 433
4500 375 435
5000 407 428
5500 425 406
6000 415 364
Man,those numbers are impressive! I'm not a drag racer by any means,I just wanted a small cube motor for semi-daily use to run on pump gas. Looks like I'll be going with the 3.42 gears instead. I can't wait 'til I'm back on the road in a couple Weeks. Thanks for that dyno Sim Techinspector.
  #51 (permalink)
Old 04-04-2013, 09:41 PM
1Gary's Avatar
Clean looking build.Nice job.
aluminum heads for a 327 sbc 67-4-fun Engine 2 05-07-2011 11:41 PM
New cam engle ep-22 will it work in a mild 327 Mr. Wormy Engine 2 08-09-2006 09:08 PM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 06:46 AM
mild 327 or mild 350 adam15425 Engine 3 10-20-2004 05:17 PM
327 GM stock aluminum intake. slider in wa Engine 2 10-25-2002 05:38 PM
