Aluminum Heater Cores - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2014, 02:35 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
I need to replace the heater core in the C10. The OEM version is brass and the new ones are for the most part aluminum. I was told that these aluminum ones can cause issues with corrosion and di-electric forces can be at play. I know that connecting copper pipe to black iron in heating systems calls for di-eletcirc unions, I would think that the rubber heater hose provides barrier.
Any concerns with using aluminum version replacement core?
Old 05-05-2014, 04:31 PM
AFAIK most anything has an aluminum core in it , probably for at least 20 years, most everything has al. radiators, if you're that concerned about it put some sacrificial anodes in the system..
dave
Old 05-05-2014, 05:12 PM
LATECH's Avatar
Attach a good ground wire to it to a ground on the body. That will negate most of the issue.
Aluminum gives off heat faster ,one reason its used in radiators. Works real well for heater cores too.
An Anode is also a good idea, plus a good brand of coolant , as coolant is also an anti corrosive.
Fact is stranger than Fiction
Old 05-05-2014, 07:37 PM
302 Z28's Avatar
A good coolant mixed with distilled water is your best insurance against corrosion.
Vince
Old 05-06-2014, 08:28 AM
Custom10's Avatar
Thanks all, I put the core in last night >>> all good.
TJ
Who sells copper radiator cores? Faceless Bob General Rodding Tech 1 10-26-2013 05:50 PM
Lunati going to austempered roller cores? eric32 Engine 2 06-22-2009 05:40 PM
whats a good price for good th-350 and 400 cores? jeffvega Transmission - Rearend 7 03-08-2009 04:15 PM
Cam Cores ? Guy Hiltz Engine 6 05-31-2008 12:03 PM
roller cams & cast iron cores 406 ss monte Engine 4 05-26-2008 07:18 PM
