Aluminum hood or steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2013, 06:04 PM
fatrat's Avatar
Last journal entry: Dave's SS 396
Hi guys, I hope someone out there can help. I picked up a 99 Ford Ranger 4x4 for my wife. It has front sheet metal damage. When I bought the hood and fenders the salesman asked if it was an aluminum or steel hood. I never checked it so I assumed it was steel. Now I realize it's aluminum. My question is besides the obvious what is the difference between the two. Will the steel replace the aluminum without any grief?
Thanks, Ed
Old 04-17-2013, 07:54 PM
Shouldn't have any issues, steel version might be cheaper price wise. I have seen a lot of the aluminum hoods with corrosion issues along the front seam/edge area. Take your pick
Old 04-18-2013, 07:15 AM
fatrat's Avatar
Thank you ppgsprayer. I picked the hood up several weeks ago, so it might have been a little tough sending it back.
Thanks again
Old 04-22-2013, 02:38 PM
Thanks, Ed
The only other possible difference is the hood hinges. I'm no expert on Ford Rangers, but on my Olds Custom Cruiser, cars with the aluminum hood also had aluminum hinges and lighter weight springs. I'm betting it's the same situation on your Ranger.
Old 04-22-2013, 03:07 PM
Banned
don't forget to go to the scrap yard and cash that hood in.
The Following User Says Thank You to killeratrod For This Useful Post:
tech69 (04-23-2013)
Old 04-23-2013, 06:22 AM
Old Fool's Avatar
Remember to prime it with SPI Epoxy to eliminate the corrosion that will develop from rock chips on the leading edge.
SPI epoxy is awesome over properly prepped aluminium, or properly prepped anything for that matter.
NO ACID etch required.
Got questions, call the SPI Tech Line @ 706-781-2220 M-F 8-5 EST
Old 04-23-2013, 08:09 AM
fatrat's Avatar
Thanks guys for the advice. I usually use PPG's DP primer but I've heard a lot of good things about SPI. As far as the hinges are concerned as long as the bolt pattern is the same I don't think I'll have any problems as there are no springs. Oh, and I definitely will not forget to scrap the aluminum hood. I could kick myself in the butt when I found out I could get $$$ for scrap catalytic converters. I scrapped 3 converters at the local DPW including one from a truck (large).
Well, thanks again, Ed
Old 04-24-2013, 05:23 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I replace a ranger hood a few years ago that had aluminum from the factory with a steel aftermarket and I think it was lighter than the factory hood.
Old 04-25-2013, 09:50 AM
fatrat's Avatar
I didn't put it on yet, but by moving it around in the garage, I think you're right.
Old 04-25-2013, 05:52 PM
Banned
The cats you gave to the DPW would have paid for the hood. now you know.
Old 04-26-2013, 09:57 AM
fatrat's Avatar
Yeah, live and learn
Flywheel aluminum or steel 72bluemalibu Transmission - Rearend 5 02-16-2011 10:15 AM
Aluminum against steel WakBordr7387 General Rodding Tech 4 02-08-2006 11:26 AM
DIY - custom steel cowls, for a steel hood? Woogeroo Body - Exterior 1 12-18-2005 07:43 PM
aluminum to steel ghastly53buick Body - Exterior 6 10-13-2003 06:28 PM
aluminum and steel himmelberg Engine 1 04-14-2002 12:45 PM
