Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - aluminum manifold, aluminum heads, bolt torque
Old 11-06-2004, 06:40 PM
edge's Avatar
edge edge is offline
Time is short, are you ready?
Just to Clarify
Will:
25 ft/lbs. when bolting the intake manifold to the heads, and do as 1BAD80 said when bolting the heads to the block. In either case, you need to follow the proper sequence. Ed.
