aluminum manifold, aluminum heads, bolt torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2004, 03:56 PM
william27103's Avatar
I can't find the torque specs for an aluminum intake manifold on aluminum cylinderheads anywhere. Can any of you guys help me? I'm having a hard time finding a book also.
Thanks,
Will
Old 11-06-2004, 05:15 PM
71ss's Avatar
what engine is, ford chevy mopar and displacement this is a bad formulated question.
chevy small block
Old 11-06-2004, 05:16 PM
Max Keith's Avatar
torque specs
I would contact the manufacturer of the heads and see what they recommend for torque specs.
Old 11-06-2004, 06:05 PM
edge's Avatar
Time is short, are you ready?
Edelbrock recommends 25 ft/lbs. Make sure you use sealant on the bolts and torque them in the proper sequence. Ed. www.edgesz28.com
Old 11-06-2004, 06:19 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
GM recommends 65ft-lb on the short bolts and 75 ft-lb long and done in 3 steps in a certain order.
Get a GM performance book from a good dealer, it gives the blueprint #s you need on the complete motor and how to build one. I prefer studs with aluminum heads and use Permatex #2 sparlingly for the watersealing ones.
Luv the smell of NITRO in the morning.
Old 11-06-2004, 07:40 PM
edge's Avatar
Just to Clarify
Will:
25 ft/lbs. when bolting the intake manifold to the heads, and do as 1BAD80 said when bolting the heads to the block. In either case, you need to follow the proper sequence. Ed.
Old 11-06-2004, 11:34 PM
lluciano77's Avatar
If you are using ARP hardware, call their techs.
With stock hardware, I would go with around 18 to 25 ft./lbs. Torque them in 3 steps.
Old 11-07-2004, 06:46 AM
1BAD80's Avatar
Wiki Edits: 2
Arrow
Sorry I did not read it correctly, I gave the head bolt specs.
