aluminum manifold renewal - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2009, 02:23 AM
techinspector1's Avatar
Wiki Edits: 326
This subject has come up from time to time when a fellow scores a manifold from a swap meet or whatever. I was surfing, looking for another product when I came across this....
http://www.aircraftspruce.com/catalo.../alumiprep.php
Old 02-14-2009, 06:02 AM
SSedan64's Avatar
Sounds like some dangerous stuff. I worked at a railroad switch & signal company years ago. Had a aluminum degreasing vat, heated liquid in bottom with cooling coils about 2ft above the liquid around outer diameter of vat kept the fumes from escaping. Can't remember the whole chemical name MethylEthylyadayadayadaydayada about that long, strong carcinogens. You just dipped the part in the circulated fumes coming off the heated liquid & grease, dirt or anything that was on the aluminum instantly dropped off.
Old 02-14-2009, 08:21 AM
302 Z28's Avatar
That is some good stuff, and gives the clean aluminum a natural look. When an aluminum part is sandblasted you can tell it right off. IMHO there are few things that look more out of place than a sandblasted OEM aluminum intake on a classic muscle car. Do not be tempted to use oven cleaner either, the caustic lye will discolor the aluminum.
Vince
Old 02-14-2009, 08:43 AM
brick acid and AC coil cleaner , but five minutes and rinse off .
watch your eye's when using , safety first.
Chevy TBI manifold with carb? Augusto Engine 13 02-10-2007 11:16 AM
What bolts for intake manifold sabino56 Engine 4 08-01-2006 07:45 PM
Aluminum Or Iron Blocks-which One Is Better ALASKAN Engine 21 04-11-2006 08:09 PM
Weiand Manifold question Andrew7dg Engine 1 08-30-2004 01:03 AM
Prepping Aluminum Interior for Paint/Clear maxx levell General Rodding Tech 3 08-31-2003 04:53 PM
