Aluminum oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2003, 08:54 PM
western star's Avatar
Aluminum oil pan
I'm looking for a polished aluminum oil pan (sbc) with the oil plug on the side in the stock postion. All I find on E-bay are the pans with the plugs on the bottom. With a low ride I am worried about shearing the plug off. Maybe it'll be fine. Does anyone know who might sell this? A website to look at? Thanks
Old 11-28-2003, 07:00 AM
Wiki Edits: 49
With a low ride I think I'd be more concerned about the pan contacting the road. Those aluminum pans are cast aluminum which will break just like cast iron if it hits something hard. Unlike steel that will dent first cast aluminum won't dent before it breaks. One good hit and you'll dump every drop of oil in your crankcase in just a few seconds.
Centerline
http://www.hotrodsandhemis.com
Old 11-28-2003, 08:15 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Try a catalog, what do you think you will get on Ebay good stuff?
This should be in the Introduction Forum for beginner's.
Luv the smell of NITRO in the morning.
Old 11-28-2003, 04:49 PM
Thank you Centerline for your input and point taken. As far as looking in catalogs? I have...many. I was trying to get some ideas from experienced Hot Rodders and usually do. Thanks
Old 11-28-2003, 05:39 PM
1BAD80's Avatar
Wiki Edits: 2
I thought you all ready know the pro's and con's and were looking for a place to buy one, as I read the posting.
Since you don't know, measure the bottom of your old pan front and rear for depth. Since you will be asked this while ordering from a catalog place for clearance reason's to the sub-frame.
Get a good one with the plug set in a recess for protection, one the side of the pan.
Steel ones only bend, either way if you hit you loose, try a skid plate if not sure to protect it.
As for a web site try Google under engine oil pans.
http://www.google.com/
Old 11-28-2003, 06:44 PM
I appreciate your feedback and will check that out. Thanks
Old 11-28-2003, 06:54 PM
1BAD80's Avatar
Wiki Edits: 2
If you get another pan don't forget to check the oil pump pickup gap to the pan. It may be different.
Old 11-29-2003, 07:44 PM
Sandflea427SS's Avatar
Anything with a throttle
it's just aluminum....would you consider plugging the hole and putting one in the place you want it....
I have a grungy polished alum. pan I'll modify for you.
Old 11-29-2003, 07:55 PM
I was told aluminum is the worst oil or tranny pan to install. Just one good size rock or pot hole that will be the end of your engine or tranny oil. Stick to tin and you will smile the miles away.
Old 11-29-2003, 08:03 PM
poncho62's Avatar
Wiki Edits: 5
The Gay one is probably right. If you want to go for looks, get a chrome plated tin pan and you won't have to worry.
Old 11-29-2003, 08:48 PM
OK guys you all totally convinced me. I'm going to steel. Thanks
Old 11-29-2003, 09:03 PM
Where do you live in Toronto I have heard that next to San Fransisco. The next biggest gay population is in Toronto. Gays can also marry in Toronto. Hats off to a country not afraid of something a bit different.
