Aluminum Rad - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2005, 07:20 AM
malc's Avatar
Living At The Speed Of Life
Aluminum Rad
Looking around for an aluminum radiator to replace my stock one which wasīnt keeping up with the heat I settled for one from Jegs.
Itīs not something Iīm going to look at everyday but even at 179.00
dollars I expected something better than this.
The gripe is the standard of welding, looks like it was done by a total novice.
Old 09-23-2005, 08:31 AM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
aluminum radiator
I also have a jegs raddiator but my welds look nothing like that. They do look pretty bad. Mine looks like a small row of cions( thats what its supposed to look like right?), but i got mine last december as a present from my girlfriend.
Old 09-23-2005, 11:48 AM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Could be worse...
I would have it pressure tested and if it passes then you can make a shroud to hide the nastiness. If you are a perfectionist, (I would not reccommend doing this on a radiator) you could possibly grind the welds down a little bit.
In the end I would think that if it kept it cool it has done it's job.
Old 09-24-2005, 04:39 AM
malc's Avatar
Like I said itīs not something Iīm going to look at everyday.
Itīs in now and when I get the top restraint/cover made it will be out of sight. Hopefully it will do itīs job.
The unprofessional welding really irked me.
ID:	7023   Click image for larger version
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
fan against rad or leave a space? smlblcks10 Engine 11 08-03-2005 06:51 PM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 02:10 PM
Aluminum rad ? x007 Engine 24 06-03-2005 08:04 PM
Aluminum rad mounting Crazy Mopar Guy General Rodding Tech 5 01-05-2004 05:14 AM
