I recently installed an Aluminum Griffin radiator and was advised by the dealer to only use distilled water in the radiator.With the onset of winter I was wondering what type of antifreeze I should use in the radiator to prevent any damage to the aluminum.
You can use any of the antifreezes on the market, because all radiators use aluminium cores.
Longtexan38 |
Jay is right, and yes, Distilled water is the way to go, Tap/Spring/Well water had lots of minerals/salt, ect that will promote corosion inside your cooling system. The only reason we change coolant is because the anti-corsion elements of the coolant breakdown after time, however, the ant-freeze elements will not breakdown. Make sure you follow that 50/50 ratio too. All coolant is just as bad as all water.
For extreme hot/cold protecton, I think a 70/30 is suggested, but check the coolant label to be sure. |
yes I agree wuth the other posts ALWAYS use distilled H2O doesnt have all the garbage you motor doesnt need
