aluminum rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2008, 11:36 AM
jgh64pkup's Avatar
Last journal entry: new et streets
aluminum rods
i have a set of childs albert aluminum rods(small journal) that i would like to put in a 283 but i don't know if they will take the rpms
Old 12-23-2008, 12:44 PM
What are the RPMs?
bogie
Old 12-23-2008, 01:44 PM
jgh64pkup's Avatar
re: aluminum rods
i was hoping for 7400 to 7800
Old 12-23-2008, 02:42 PM
Assuming they're in good condition there's no reason why you can't turn those kind of revs.
The big enemy of aluminum rods is fatigue fracture which is the result of work hardening that comes from the constant changes in loading from compression to tension and back again as the engine passes thru its cycles. This alternately stretches then compresses the rod which is something that aluminum has problems with when it's encountered over a long period of time.
For this reason in a race engine the rods are frequently inspected for stretch and cracking. In street engines and long distance racing engines it is often felt that aluminum rods don't offer sufficient longevity. But there are plenty of exceptions to the popular wisdom.
Aluminum rods are nice with blower and nitrous engines as well as those running rocket fuels like nitro-methane and will offer some protection to the rod bearings on engines that run in detonation as the aluminum will give a bit softening the blows on the crank journals.
Be sure to re-balance and add about .010 to .015 inch clearance between the piston crown and the head's squish/quench deck as aluminum rods will thermally grow more than steel rods so without a little additional clearance there is the risk of running the piston into the head.
Bogie
Old 12-23-2008, 03:34 PM
techinspector1's Avatar
Wiki Edits: 326
When checking ferrous metals for cracks, a magnetic procedure is used (magnaflux). Since aluminum is non-ferrous, a dye penetrant procedure is used. See if you can find someone in your area who can Zyglo the rods before you install them or purchase a Zyglo kit and do it yourself....
http://www.magnaflux.com/penetrant/penetrant.stm
Old 12-23-2008, 05:33 PM
OHD's Avatar
OHD OHD is offline
If they are used aluminum rods do not use them in a fresh rebuild.
They were removed for a reason...
Old 12-23-2008, 08:50 PM
jgh64pkup's Avatar
re: aluminum rods
can a 283 be bored .125 over to a 4 inch bore without any cooling issues
Old 12-23-2008, 08:59 PM
coldknock's Avatar
Have the block sonic tested for cylinder wall thickness. I built one at 0.100" over and loved it.
The cooling issues are a myth perpetuated by people with an inadequate understanding of how to put together a properly functioning cooling system.
Larry
Old 12-23-2008, 09:09 PM
jgh64pkup's Avatar
re: aluminum rods
i found some forged dome pistons to make a 302 out of a 283 would that be worth the trouble
Old 12-23-2008, 09:16 PM
coldknock's Avatar
A 4" bore is a necessity to fit anything larger than 1.94/1.50 valves. Soo, if you want it to breathe and make some power you need to have at least 3.975" of bore for 2.02/1.60 valves, and actually use them.
If you can get the 302 pistons for a reasonable price, and the block checks out for a 0.125" over, go for it.
Larry
Old 12-23-2008, 09:24 PM
Wiki Edits: 326
"The cooling issues are a myth perpetuated by people with an inadequate understanding of how to put together a properly functioning cooling system."
Eloquent. I have a deep appreciation for a well-structured sentence.
jgh, have the cylinder walls beeped. If they will be minimum 0.135" after boring and honing, go for it.
Old 12-23-2008, 09:35 PM
jgh64pkup's Avatar
re: aluminum rods
my buddy has the pistons and it has small journal mickey thompson aluminum rods he also said he'll throw in the crank
he said since they were in his shop collecting dust he would sell them to me for 100 bucks
Old 12-23-2008, 09:38 PM
jgh64pkup's Avatar
re: aluminum rods
I also have some powerpack heads i would like to ream and put bigger valves in would 2.05/1.60 be too much for the 302
Old 12-24-2008, 07:28 AM
bondo's Avatar
Ayuh,...
Are you even Reading the responces offered to you here,..??
What is the History of those Aluminm Rods,..??..??
If they're Used,... They're Junk,.. Wall hangers,.. NFGood.....
That's the Answer to your 2.05" Valve Question.....
Old 12-24-2008, 04:04 PM
jgh64pkup's Avatar
re: aluminum rods
do you think it will not have enough torque on the low rpms for a street truck since most of the power is from about 3500 up
Are these sbc 5.7 rods any good? eric32 Engine 10 09-08-2008 09:55 PM
BBF connecting rods fourtwoseven Engine 0 03-04-2006 04:15 PM
5.7 rods in 400 joefromcocomo Engine 9 02-05-2004 12:59 PM
Prepping Aluminum Interior for Paint/Clear maxx levell General Rodding Tech 3 08-31-2003 04:53 PM
aluminum rods on the street iniguy Engine 6 04-21-2003 07:42 PM
