Aluminum SBC Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2009, 10:42 AM
Aluminum SBC Heads
I have a 400 sbc 1970's with matching cast iron heads, I am looking to purchase a pair of aluminum heads just to stay cool, and to be quite honest I just have a feeling they're better. I don't have a real idea of which heads I need so my research starts here. I've got long tube headers and an edelbrock aluminum intake, 785 cfm edelbrock q-jet carb. Planning to change the cam, but currently just have an edelbrock torquer cam ( i want to get roller lifters with a mild lope cam for this motor as well, i would look for "retro-fit" roller lifters, right?). I've found some bowtie aluminum heads, dart aluminum heads, procomp aluminum heads, and then edelbrock aluminum heads. I was told when comparing the bowtie's to the edelbrocks it is like comparing apples to oranges, is that true? I'm just a young buck that blames most of his knowedge on the old timers i run with, DIY guy to the core, that's why im here, any information or two cents you care to spit will be appreciated, even if you think i should keep the old heads, thanks and May God bless.
Old 03-01-2009, 11:11 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Straight comparison (for instance, the same casting done in aluminum vs. iron) have shown little or no benefits to the engine operation. In fact, iron sometimes makes a 1/2 hp more because it reflects more heat back into the combustion. Aluminum's benefit is that you can often get by with a tiny bit more compression before stepping up the octane... rather, it should be said that aluminum heads sometimes require more compression to recover lost cylinder pressure because they absorb heat from combustion faster.
But, the main benefit of aluminum is weight. Period. Don't get them because they're higher performance. But any iron head (provided it gives you the right compression and flow for your goals) will do just as well as the same head cast in aluminum... but the aluminum will cost a lot more.
Let's start with your goals. We can't pick good heads for you unless you know how much power you want to make? HP goals? RPM goals? Budget?
Old 03-01-2009, 04:08 PM
Aluminum Sbc heads reply
thanks for the input... my goals are for a street and strip pickup, a Friday night Stoplight kicker, someday I'd like to take it to the track(who wouldn't)it won't live there though, but definately not a long distance, 2 hr drive at the Most. 700r4 will have an overdrive and all the bells and whistles on it to handle the motor. rearend is stock(for now). I'm on a budget yes sir, recession is talking to everyone. I also just want it to run on regular fuel. hey, I thought about vortec heads on this old motor but was told those heads only work their magic with the computer setup attached, what do ya think?...thanks again for your input, makes dang good sense.
I want to hit 400hp, keep rpms low
Old 03-01-2009, 08:31 PM
curtis73's Avatar
Wiki Edits: 16
400 hp says Vortec to me... and whoever told you they work best with a computer is full of hooey Airflow is airflow, doesn't matter if its carbed or EFI.
But if you want aluminums, look to some of the Summit heads. Trick Flow makes some nice street aluminum heads, but pay close attention to what you get for your money. Vortecs flow about 237 cfm intake flow from nice streetable 170cc ports. To get that much flow from most aftermarket heads it will take 190cc or more, meaning you'll be giving up very valuable torque, throttle response, and streetability.
Old 03-12-2009, 02:53 PM
SS66chevelle's Avatar
HR VIOLATION
I didnt see mention of the de-facto goto heads - AFR so I thought I might throw that out there.. (for all the talk about AFR heads I've seen maybe 3 cars that actually run them outside of car craft magazine). Anyway my zz502 came out of the crate with edelbrock performer RPM's which are a pretty good bang for the buck in the summit catalog..
Old 03-12-2009, 03:12 PM
The Edelbrock Performer RPM is what you want.
Old 03-12-2009, 06:34 PM
Are these good heads. I picked up a set new for $350. They were never installed. One of the heads had a scratch so I paid $60 additional to have a tenth taken off both heads. They recommended I mill both and not only one. It was so small the performance shop I took them to said the gasket may actually seat it. You could get a fingernail (small piece) of it in the groove. They guy doesn't know how it happened other than they were set down on something. I had them checked and they said I scored. Just wanting to know if they were any good. The guy I bought them from wanted $500, but I was a little hesitant with the scratch on the head. Just as I was walking away to get in my car.. he said.. ok I'll let you have em for $350. I bought them and went straight to the speed shop to have them checked. I was a gamble.. but it paid off. He was going to use them on a 327. I plan on using them on a mild 350.
I am still tickled pink over getting them so cheap. It was either them or Vortecs for $50 bucks more from another seller. Those were new still in GM boxes as well.
Old 03-12-2009, 08:10 PM
curtis73's Avatar
Wiki Edits: 16
I'd say that's a definite score.
Old 03-12-2009, 09:43 PM
Yeah, got em so cheap, I was thinking about not using them.. and saving them for something I can build a little more on the wilder side with. I am building a motor for a truck right now, so not sure how good they'll be for a daily driver heavier type car. Although, they are only 170cc runners so not that big of a head runner wise. Much better than stock though for sure.
Old 03-12-2009, 10:07 PM
automotive breath's Avatar
We use the Edelbrock Performer RPM heads for bracket racing. They work
great with mild porting on a 350 - 355 CI engine to 6500 -7000 RPM.
Old 03-13-2009, 12:40 AM
What would the CR be with a dished piston with 64cc edelbrock heads. You have any you can recommend. I thought the dish piston would lower compression in this case.
Old 03-13-2009, 02:39 AM
retrofit hydraulic roller set up
crane powermax hydraulic roller cam and lifters/pushrods have less than 500 miles on this set retrofit lifters cam specs intake 539 exhaust 558 106 lobe separtion real choppy hard hitting cam rpm range 2800-6800 296/304 adv. duration jegs part number 270-119841$349.99 also crane hyd. roller lifters cost $400and also crane push rods cost $107 and double springs 270-99893-16 and retainers 270-99969-16 value of over $160 plus keepers .....................dont need any more going bigblock looking to get 400 plus shipping............
had this cam in my 355 sbc 040 sportsman2 heads car ran very well 3000 stall real choppy real nice cam very streetable paid over 1000 bucks for whole set but no ive stepped up to big block 496 so dont need no more
Old 03-13-2009, 11:28 AM
Originally Posted by F-BIRD'88
A street 400SBC that runs everyday on pump gas (92 octane) needs a dished piston (18 to 22cc) when using a 64cc cylinder head.
A flat top piston 400SBC uses a 70-76cc cylinder head for pump gas.
Both KB and Federal Mogul/SpeedPro have lots of good Forged and high perf Hyper piston choices for this.
For a 406 SBC street motor using a 5.7" connecting rod and a 64cc head I recomend the UEM/Keith Black KB-168 with a "0 decked" block. 9.8:1 compression.
What about for a 350 based block.
Old 03-13-2009, 11:55 AM
doesnt matter
still will work
Old 03-28-2009, 04:53 PM
400sbc Update
Just got done buying all high performance parts for a 700r4 tranny rebuild, about to send the tranny and the parts to the rebuild shop, I am not sure if the cam I have in the 400sbc is a torker II, think it is just the edelbrock torker I? My rear end is stock for an 82 half ton gmc pickup, I think they are 3.73s. I've been hunting vortec heads ever since I got a couple replys on this discussion board. I found some good priced heads, and found some aluminum vortec heads, but still not sure if any would fit my motor, my pistons are flat tops, so now i know that i need 70 cc, thanks for the info. The only thing that is throwing a wrench in my plans is that I am told I will have to change intakes if i get vortec heads. My edelbrock intake is brand new I don't want to set it aside, and yes my edelbrock Q-jet fits perfect on it. Edelbrock heads are pretty high for right now, but maybe I'll save up for em, if they are better than the vortecs?-there's a question. Thank you thank you for all your input, I'm learning a bunch, you guys are kick. May God bless.
Aluminum SBC Heads # 10088113 vette eatonde Engine 7 02-15-2009 06:42 PM
Aluminum vs. Cast Heads On SBC S10 Racer Engine 7 01-09-2008 06:05 PM
SBC Aluminum heads, AFR vrs Edelbrock etc... Gladis Engine 4 10-19-2007 03:52 PM
head ache. sbc heads excaliberprime Engine 7 03-07-2007 07:03 PM
SBC Heads interchange JasonKyle Engine 5 05-06-2006 09:08 PM
