Aluminum Strip with Rubber Insert - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 06:39 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Back in the saddle again - almost
I'm looking for a source for the subject item. I'm looking to install these aluminum strips with rubber inserts on my running boards for protection after painting.
So far I've only been able to find them in the UK. See the following link which has a diagram.
http://classic-auto-parts.co.uk/part.phtml?PartID=827
Was wondering if anyone knew of a stateside vendor for similar items???
Old 05-26-2008, 07:57 PM
Years ago there was universal side moulding kits that were of that design. They were cut to length and were pop riveted on. Try doing a search under side moulding kit.
Old 05-26-2008, 08:10 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I do not know what vehicle you are building, but mid-fifty ford parts sells them for our fords.
http://www.midfifty.com/
They are called "Custom runner kits". They come in black and several other colors.
They look really good on the trucks. I have seen them after installation.
I am just installing the "ford" step plates on mine.
http://www.customautotrim.com/produc...ings/rivet.htm
Old 05-26-2008, 08:27 PM
Also, you might want to search the marine industry for rub rails and similar, and I bet you could find them in stainless. http://www.mysticmarinediscounts.com/hardware-rub-rail---moulding.html
Old 05-27-2008, 09:49 AM
tc33's Avatar
Stuck in the 30's
re: Aluminum Strip with Rubber Insert
Thanx Baddbob and all. Exactly what I'm looking for. By the way I'm looking to install on my 1936 Chevy running boards for protection.
Check out my project journal for details.
Handbuilt aluminum body ckucia Body - Exterior 25 07-18-2007 12:15 PM
Aluminum welding made easy and cheap! daimon1054 General Rodding Tech 17 03-19-2007 07:34 PM
Painting an aluminum block Arrowhead Body - Exterior 4 10-28-2005 07:13 PM
Why use aluminum heads? newchevyman Engine 17 07-29-2005 08:31 AM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 05:46 AM
