Aluminum timing cover SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2013, 06:27 PM
fastnloud's Avatar
My 82 c10 has an aluminum/billet timing cover on it, but it has no timing tab/pointer on it. I'm needing to get one for it.
What kind of timing tab do I need? I think some of the regular tin ones won't work properly with this cover right?
What about this?
Spectre Performance/Timing Tab - Performance (4237) | AutoZone.com
Thanks guys.
Old 04-28-2013, 06:46 PM
Banned
what size balancer?
The Following User Says Thank You to gearheadslife For This Useful Post:
fastnloud (04-28-2013)
Old 04-28-2013, 06:51 PM
BOBCRMAN@aol.com's Avatar
None of the stamped steel timing pointers, that I have seen, will work correctly with the cast aluminum covers. I know the Spectre will not. The correct one is also billet/cast aluminum.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
Old 04-28-2013, 07:03 PM
ericnova72's Avatar
More for Less Racer
You need Spectre #4936 Polished Billet Aluminum Timing Tab, for balancers 6,7,and 8" in diameter. Pointer is adjustable to fit all 3 sizes according to the listing, but you may want to verify.
This type of billet tab is the style you are looking for to fit an aluminum cover.
The Following User Says Thank You to ericnova72 For This Useful Post:
Old 04-28-2013, 07:43 PM
fastnloud's Avatar
Originally Posted by gearheadslife View Post
what size balancer?
I believe 8 inch.
Thanks for the info.
Thanks, I will give that one a try.
Old 04-30-2013, 07:31 PM
fastnloud's Avatar
The Spectre Aluminum timing tab seems to be on backorder everywhere. Does anyone know any other brands of these aluminum timing tabs that will work with all the different size balancers? I'm having a hard time finding them.
Old 04-30-2013, 07:52 PM
Seems like I ordered a house-brand one from Summit. I think.
PatM
Old 04-30-2013, 08:06 PM
techinspector1's Avatar
Wiki Edits: 326
Not to sound like a smartazz, but if you haven't verified TDC, the pointer will be useless anyway.....
http://www.crankshaftcoalition.com/w...op_dead_center
The Following User Says Thank You to techinspector1 For This Useful Post:
fastnloud (04-30-2013)
Old 04-30-2013, 08:15 PM
fastnloud's Avatar
Yeah, when I get the pointer, we will be verifying TDC, installing the pointer, and then working on the timing.
Old 05-01-2013, 10:34 PM
I did check Summit. They have a large variety of timing pointers for various OD balencers.
PatM
The Following User Says Thank You to PatM For This Useful Post:
fastnloud (05-04-2013)
Old 05-04-2013, 04:07 PM
ericnova72's Avatar
More for Less Racer
Competition Products in Oshkosh, Wisconsin is another good source.
Good pricing too.
Old 05-04-2013, 08:49 PM
fastnloud's Avatar
Thanks guys. I ended up finding the Spectre aluminum pointer in stock at Amazon.com.
SBC timing cover ? Madmax305 Engine 9 05-25-2010 10:03 PM
First time timing cover install on my SBC... how does this look? v8hed Engine 5 08-02-2008 02:34 PM
SBC timing chain cover interchangeability curtis73 Engine 4 11-23-2006 02:00 PM
timing cover bolts sbc stea Engine 5 06-27-2004 09:55 AM
86-up sbc timing cover...??? nastynova Engine 6 01-20-2003 05:48 AM
