Aluminum Water pumps, what's their advantage? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2005, 03:11 AM
Jeeps Are Us!
Last journal entry: The Paint Shop
Hi everybody.
I was comparing Weiand Aluminum Water pumps with Edel's and was wondering why are Edelbrocks almost twice as expensive as Weiands water pumps?
On the other hand, is there any advantage of using Aluminum pump over using cast iron water pumps?
This is regarding Small Block Chevy.
Please advise me on this, I really don't like to pay that much for water pump, if ther's no real difference.
Thanks,
Houman
Old 04-26-2005, 04:27 AM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
IMO it is not worth the money, You will save some weight by going to alu. and it will transfer heat better (just like alu. heads) but on a street car I really don't think there is any need for it. Maybe if weight was a uge issue then yes but save your money.
Chris
Old 04-26-2005, 03:21 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Chris
I agree with this, the minuscule weight savings really isn't worth the extra expense.
Buy a quality cast iron pump and save the money for something else, unless you really like the look of aluminum.
Old 04-26-2005, 04:21 PM
x007's Avatar
Supercharged T/A
There is a big weight diff. !! , i have an edelb. alum. "permastar", they are several pounds less than cast water pump.. 30% more flow also..
-= Build for Power =-
Old 04-26-2005, 05:57 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I think with the Edel pump your paying some for name, but then again your getting name brand. Id get a Miloden pump. 71 bucks and 30-40% more cooling than stock. Just my .02. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 04-26-2005, 07:18 PM
$71 not to bad... The thing with cooling system is that most people don't seem to have a problem with cooling running 500Hp engines with cast iron water pump. Yes a working cooling system is a must but there are plenty of cast iron pumps on 500Hp mosters. If your not replacing the rad. then it might be cheaper to buy the water pump. As long as the engine is not over heating the way it is I see no reason to change.
Chris
Old 04-26-2005, 08:42 PM
Ghetto Jet's Avatar
Several pounds? You need to ditch about 100 pounds to knock .10 of you're quarter time. The 5 or so pounds you save with a aluminum pump really isn't doing you any favors. Also every mechanical water pump, iron or aluminum, is advertised as having 30% more flow.
I paid $74 for my Milodon pump, it's a quality piece. I know Coldknock has been running the same iron Milodon pump on his last 3 sbc's and it's still going.
Old 04-26-2005, 08:52 PM
x007's Avatar
Supercharged T/A
i'm sure there are near 10 pounds if not more, the alu. is realy light.. btw the reason why i have changed it is for the shiny look & weight, saving some pound here and here is always helpfull since my car starting to be loaded.. this may not hurt!
Old 04-26-2005, 08:54 PM
daimon1054's Avatar
I agree! 5 pounds way down low is squat and on a street car the steel will be much stronger, if you over tighten the belt in and alloy pump you will toast it PDQ.
Old 04-26-2005, 09:09 PM
coldknock's Avatar
You can make aluminum shine real good and they don't hurt your back when you're bent over the car lining up the bolt holes. That's about it.
Larry
bbc water pumps 68chevelle_ss Engine 7 04-24-2004 04:17 AM
electric water pumps??? classic_chevy_guy Engine 3 10-24-2003 10:09 PM
Milodon High Volume Water Pumps Jag Daddy Engine 2 04-11-2003 06:15 AM
Need water pumps. senor_limpio Engine 5 12-02-2002 08:59 PM
Hi Volume Water Pumps jpspridd Engine 4 08-20-2002 09:55 AM
