Aluminum wheel lugnut torque - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2010, 03:17 PM
47 Coupe's Avatar
The manual for my 2007 HHR shows 100ft/lbs. There isn't anything different for aluminum wheels. That seems kinda high for aluminum wheels to me. Does anyone know the correct torque?
Old 02-02-2010, 03:45 PM
T-bucket23's Avatar
Wiki Edits: 26
100 is in the range. Most factory specs are between 90 and 120
Chet
Old 02-02-2010, 04:43 PM
Torque lug nuts to 100 on anything bigger than a Metro and smaller than a full-size pickup and you'll be fine. Like above, the range is 80 to 120 generally speaking.
Old 02-02-2010, 04:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I always torque mine at 85, And have always known it being in the range of 80 to 120 depending on the stud size.JMO
Cole
Old 02-02-2010, 05:23 PM
sqzbox's Avatar
My pipes are my music
Maybe HHR's only come with alloy's. I was told that whatever you torque the wheels too, That the torque was just as much about having uniformity on all nut's to prevent warpage of the rotors as it is about keeping the wheels on not to mention preventing over torque on the lugs and nut's.
We all know what happens when you do that! They break!
Good read on this is in the hotrodding basics forum titled "how do you install wheel studs"
If you have ever replaced a wheel stud, you might be a "butcher"
Old 02-02-2010, 05:43 PM
47 Coupe's Avatar
Thanks for the response. I changed out my rotors and torqued the wheels to 100ft/lbs.
thanks again
Need emergency advice on rod bolt torque issues. eric32 Engine 11 05-27-2009 05:41 PM
wheel lug torque specs perryb General Rodding Tech 2 04-16-2007 03:44 AM
Wheel Torque Specs Canadian Charlie General Rodding Tech 2 03-12-2007 05:51 PM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
Wheel bearibg torque for Escort? BT74 Suspension - Brakes - Steering 4 05-30-2004 09:11 AM
