Aluminum Wheel Painting / Aluma Prep Application Help Needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 02:46 AM
I have lightly blasted a set of 15 spoke turbine style wheels and wet sanded the fins and rings with 1500 grit. I am happy with the results of the sanding and have taped them off for web painting to color match to my vehicle paint. My question is; what is the proper name of the acid etch needed to wash the taped off wheels before I spray on the color? I'm not a body & paint guy but know enough to shoot some wheels. I haven't done aluminum by myself and would like some info for the do it myselfer. I've been told the aluminum needs to be etched prior to painting.
Old 04-06-2009, 03:46 AM
Last journal entry: 50 Ply wagon
There are etching primers on the market. I think Eastwood has one, but not sure if it works with aluminum. I would check with your local body shop supply place and they will point you in the right direction.
Old 04-06-2009, 09:07 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use an self etching epoxy on alloy that saves me a lot of time and gives a better job IMO..Just blast and paint that way..
Sam
Old 04-06-2009, 06:42 PM
Hey Sam, is this etch actually in the paint or is this a separate procedure prior to paint. I would think it's not in the paint? Is it something I spray on and rinse off with water then dry before painting? Not to sound to dumb here but I'm learning? John
I will ask the local Industrial finishes store here about Aluminum etching materials. Thanks for your replys Guys!
Old 04-06-2009, 07:58 PM
Last journal entry: More painting pics
I have used Alumiprep 33 followed by Alodine then epoxy prime etc. and seemed to work well. Here is some good info
http://www.ronjoseph.com/painting-aluminum.htm
http://www.ronjoseph.com/Q&A/B2001_p...g_aluminum.htm
Vital that Al is prepped correctly then primed shortly after so as not to allow the oxide coat to reform.
Old 04-06-2009, 08:27 PM
remember you only have 8 hours to spray aluminum after you sand/skuff it to make sure it gets proper adhesion most people forget that but i had it drilled in my head when i was doing an aluminum boat while working at a bodyshop
and use a wax and greese remover before you spray
This is what i use
https://buyat.ppg.com/refinishProduc...e-a2400381ed7c
hpe it helps
Old 04-07-2009, 03:58 AM
Good info guys. Thanks for your time! Jmac
What's needed to wire a horn at the steering wheel? jpd37 Electrical 9 06-22-2009 07:53 AM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 07:02 PM
help on back-half project. can't find aluminum wheel tub liner remote Hotrodding Basics 2 08-18-2006 12:45 PM
wheel info needed rmemech Hotrodding Basics 4 06-05-2006 06:39 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
