Am I doing this right?? HVLP pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2005, 01:49 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I just got a FL3 HVLP gun and have used it a couple of times for primer but I'm not sure if I'm using it right. The directions say to set the gun at 23psi inlet pressure. When I set it I have the gun flowing(air only) and the static pressure is about 105psi. When I've been shooting primer it goes on very nice but I notice that I still have allot of over spray in the air and allot of over spray dust on the floor when I'm done. If I set the gun at 23psi static when I flow air the pressure drops to zero, I haven't tried to spray with the setting like that. Which way is correct or do I just need to lower/play the pressure a little more.
Thanks
David
If it makes any difference I've got it hooked to a 7hp, 60gal compressor with 13.5 cfm at 40 psi.
Old 08-09-2005, 06:19 PM
Have you set the pressure at 23 psi before you press on the gun? If you do so the pressure will drop when you shoot. You need to set it at 23psi "when" you shoot the paint. That thing happened to me the first time I sprayed paint and I didn't know what was going on. I hope it helps you.
Old 08-09-2005, 06:31 PM
rrmccabe's Avatar
GM Muscle
That 23psi is supposed to be at the gun when you have air flowing. To do this you need a air guage at the gun. IF you set your regulator at the compressor at about 25psi you will be close. Air line has a certain amount of drop depending on length.
If you have your compressor regulator set at 105 then you need some type of device at the gun to regulate.
Rich
Old 08-09-2005, 07:18 PM
The regulator at the gun needs to be a true diaphragm type and not one of those cheapie flow restrictors that do nothing more than choke the flow down. The choke-down type have a gauge and are called regulators but they will let the pressure vary with air line pressure while the real regulators will maintain a constant PSI setting regardless of line fluctuations.
Old 08-09-2005, 07:23 PM
Toyman's Avatar
To keep within the governmental regulations for an HVLP gun, you need to have 23 psi at the inlet pressure to get 10 psi at the cap. But, if you have a little more pressure, you won't be as efficient or within the govt. regs for HVLP, but you will get better atomization. Your best bet is a diaphram regulator at the gun, not a "cheater valve". Set your regulator where ever you like & set the gun regulator at 23+ psi with the trigger pulled. You only need to pull the trigger to "air". It is not necessary to spray paint to set pressure.
Old 08-09-2005, 07:32 PM
rrmccabe's Avatar
GM Muscle
I am to the point I am removing the regulator from the gun just so I dont have the bulk. I have a T now with a 0-50 guage that I can insert and use to set my wall regulator. Once set, I remove the guage.
So far, I think its the best thing going. Needle valves and diapram regulators are restrictive which is not good with HVLP.
All you care about is knowing what your psi is at the gun when you are spraying. It should not change assuming your compressor keeps up, once its set.
No more regulator at the gun for me
Rich
Old 08-09-2005, 09:06 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
That gun comes with the regulator for it. The gun is designed to be used with a hobbiest typical compressor,generally a 33 gal. variety.
Adjust the reg. with the trigger pulled fully IN and your set. I have run mine higher,up to 30 psi with good results.
Spraying primer is a mess anyway as it's more product being put out than when painting and the residual is more noticable as well.
Any gun be it conv. or HVLP will make a cloud when using primer using the larger tip so don't sweat it too much.
I agree on the gun reg's being a problem IF it's NOT designed for that perticular gun.
I used a D'Villbliss reg on my Iwata and it just could not get the psi up unless the wall reg was CRANKED. I opened it up and after SEEING the TINY opening was convinced about not all diaphram reg's are equal.
I got a different reg today and all's well with it now.
My hose reg is outside the booth and is a major pain to readjust if it's not right,so for now,I'll stick with the gun reg. but as Rich said mine are on the way OUT.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
HVLP Pressure jcclark Body - Exterior 14 06-16-2005 03:50 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
air pressure on the harbor freight hvlp? project66 Body - Exterior 7 09-27-2004 02:40 PM
