Am I overcharging?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2007, 09:54 AM
Am I overcharging??
I Just purchased a new gel battery and before I put it in I wanted to throw on a multi meter to see what my alternator is putting out.
I tested it and its putting out about 14.6 volts at idle. I know normally an alternator should put out 14.4 volts so is 14.6 too much or not a big deal?
Thanks
Old 06-15-2007, 10:50 AM
streetrodderbn's Avatar
Certifiable Streetrodder
This is really not a big deal, your multimeter probably has a greater degree of error than that
Old 06-15-2007, 10:59 AM
302 Z28's Avatar
I agree, that difference is well within the margin of error for a digital meter, especially if it's a cheap one.
Vince
Old 06-15-2007, 01:46 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
14.6 is not an over charge..It's well within the window for charging, However if it worries you, and you have a 3 wire alternator, you might try moving the remote sensing wire The small red wire) to the solenoid "BATT" terminal .
This will turn the regulator on later, and shut it off sooner than it would were it at the "End" of the load..
However, I suspect you may be looking at different resistance levels of the cell structure between a gel, and Liquid H2SO4 Cells..which may account for the .1 Volt difference..to verify, after running for a while, shut it off, remove a battery cable and measure..IF it reads 14.6 , it's cell structure differences. Either way it will have no effect on the battery or charging system.
The ONLY time you should worry is when it starts approaching just under 15 , 15.5 Volts..then it's over charging.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-16-2007, 05:38 AM
Thanks for all the help guys
altinator overcharging walkn slow Electrical 2 03-20-2007 10:09 AM
chevy alternator overcharging at higher rpm tim2 Electrical 3 11-02-2003 10:28 AM
Voltage Readings on New Gauge - Overcharging? horvath Electrical 9 05-19-2003 03:49 PM
