Big Al Last edited by adantessr; 02-09-2012 at 10:34 AM. |
Get rid of the line in the basement, I really don't think you need that with a good dryer installed. Run a larger line to the garage, 3/8 minimum. Depending on what you use the air for, 3/8 should suffice for everything but the largest tools and your compressor likely won't run those well. The more air hose you run, the more volume you will using. I don't remember the formula, but for every foot of hose, you lose a little pressure. Try this:http://www.gates.com/industrial/pres...043#calculator
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
The 3/4 line is fine, so is the 1/2 .
the problem is the 1/4. No matter how big the pipe is on the receiving end the most air you can get is what the 1/4 will flow. replace it with a 3/4 hose . |
Here is the calculation using the Gates calculator
Showing 100 psi at the compressor and 15 cfm output with a 30 foot run you will have a pressure loss of 27.97 psi with 1/4" hose, 3.32 psi with 3/8" hose and .73 psi with 1/2" diameter hose. Thanks to DINGER for the link to the calculator.
So the choice is yours. How much pressure loss can you live with ?
It is really nice to be visiting your post. I found it very informative.
u just put an orifice in the line..
u can put in a 3" pipe all the way... and in the middle u put in a 1/4" pipe.... the max flow is what u get through the 1/4" only.. the bigger pipe is storage of air, not flow...if u change to a 1/2" pipe all the way u'll be fine... keep the elbows to a min too..
| Recent Garage - Tools posts with photos |
| Oil.. how does it flow around an SBC? | duncan_m | Engine | 10 | 12-24-2008 07:05 PM |
| enough flow to go? | camino_man | Engine | 7 | 07-11-2004 01:26 PM |
| flow | 78 chevy truck | Engine | 4 | 11-11-2003 01:29 PM |
| flow | 78 chevy truck | Engine | 2 | 11-06-2003 03:54 PM |
| over flow | cc69 | Engine | 2 | 08-25-2002 08:49 AM |
